solid motor mounts
Old Nov 13, 2001 | 09:18 PM
HotRodTeg's Avatar
Default solid motor mounts
Ok if you guys could help me out i would be very thank full. K i have a 90 CRX and im dropping my b20 into it does any one no where i could get solid motor mounts for it or would have to wield my own.
Old Nov 13, 2001 | 11:11 PM
93LSivic's Avatar
Default Re: solid motor mounts (streetracer)
Umm, dude i hope that you are frasing your question wrong. Solid motormounts? I think your thinking about maybe the stiffer motor mount bushings.
If not then I dont think you would like have the motor basically mounted firmly to the car. Mad **** would go wrong, plus just your teeth chattering together would be enough to make you wear a mouth piece......
Old Nov 13, 2001 | 11:29 PM
Backyard Speical's Avatar
why not just go with the place racing mount kit. give me a call i'll try to give you a good deal on those mounts.
Old Nov 14, 2001 | 12:23 AM
Mista Bone's Avatar
D Tranny Guru
I should be a dentist if you want solid mounts!
Better tack weld all bolts first else they will come loose.
Old Nov 14, 2001 | 01:31 AM
GZR4DR's Avatar
Default Re: solid motor mounts (Mista Bone)
Solid mounts are for drag only cars. No one in there right mind would drive that **** on the street if they had any sense.
Old Dec 14, 2002 | 10:58 AM
Kataku2K3's Avatar
Default Re: solid motor mounts (GZR4DR)
Holly bejeapers, you crazy nut you, j/k Scott... This was gonna be a race car so that solid mount would have been fine.... Oh well you don't even have that car anymore...
Old Dec 14, 2002 | 12:03 PM
jdmDXrex's Avatar
Default Re: solid motor mounts (JDMspecEG6)
scott...... i thought i told you.... u need to quit being shady about all your ****... are you going for your 3rd CRX already??? well i guess good luck with the solid mounts... peace out homie
Old Dec 14, 2002 | 02:58 PM
Kataku2K3's Avatar
Default Re: solid motor mounts (jdmDXrex)
Mike that was a long time ago when he had his first CRX...... hehe, I was just looking seaching around and found him... Latez
scabbs
Sep 17, 2007 09:57 AM
GoCarInteg
Jul 27, 2005 11:31 AM
Rod.
Jul 2, 2005 11:49 PM
P'nut
Dec 10, 2004 06:38 PM
bigTom
Jan 27, 2002 05:01 PM
