Solid Check Engine Light
Old Sep 11, 2006 | 05:38 PM
project_hatch1.8's Avatar
Default Solid Check Engine Light
*I searched and found no definitive answer*
I checked to see if my ecu was throwing any codes after the swap and all I got was a solid check engine light. Does this mean that there are no codes or that the ecu is bad. In the threads that I've searched different people said dirrent things. Also, if it does mean the ecu is defective, can it go bad from sitting in a car outside for about a year and a half? possibly from moisture or something? And is it likely the whole ecu is messed up? I ask because I am getting no spark.
TIA
edit: by whole ecu i mean is it likely that it is causing now spark versus just running shitty
Modified by project_hatch1.8 at 7:41 PM 9/11/2006
Old Sep 11, 2006 | 05:49 PM
Default Re: Solid Check Engine Light (project_hatch1.8)
also, its a chipped p28, if the chip was bad it would still have spark correct? I took the ecu cover off and visually everything looks fine
Old Sep 11, 2006 | 06:08 PM
Bense's Avatar
put your flame suit on and step over to pgmfi.org
Old Sep 11, 2006 | 06:28 PM
Default Re: Solid Check Engine Light (Bense)
I shouldn't need my flame suit hopefully, I asked a question after searching previous threads. And I know next to nothing about electronics and computers when it comes to cars! Anyway the link you posted helped a little, i found a couple threads that said that a solid cel means a deffective ecu
Old Sep 11, 2006 | 06:46 PM
L33TsAbabyEater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">put your flame suit on and step over to pgmfi.org</TD></TR></TABLE>
The reason you need your flame suit is because PGMfi.org is becoming more and more well known to everyone on HT. If you ever have a problem with electronics, be sure to hit up this site before you say you searched and couldnt find an answer.
By the way project_hatch1.8, is this Will from stanwood?
Old Sep 11, 2006 | 10:16 PM
Default Re: Solid Check Engine Light (WhiteBread)
na, im not from stanwood. I don't come in this forum often so I haven't heard of pgmfi.com, I can probably count all the times on one hand. Actually come to think of it i have heard of that site before. Anyways, thanks guys
Old Sep 13, 2006 | 11:51 AM
turbohf's Avatar
hey, if you start your car (or just turn it to the ON position for more than 3 seconds) the CEL will come on for ~3seconds then go off. if it does that your fine and there are no codes. if it comes on and stays on you have a code and then you need to jumper it to check them. when your checking them it will blink and all that ****, if at that time it has no blinks and is just solid THEN you have a problem... but if the CEL on the dash isnt on then you jumper it, it will show a 'solid CEL'...
Old Sep 14, 2006 | 07:55 AM
jays93eg6's Avatar
Default Re: Solid Check Engine Light (turbohf)
If you are running a chipped P28 you could very easily have a bad chip. I have had more than one person from right here on Honda-Tech make me a chip and it do the same exact thing. I remove the chip they made and reinstall the cheap *** Ebay chip I got with the ECU and everything works good. So if I were you I would try and find someone to make a chip for you. Plus try and get chrome, because Uber is mainly the one that has been used for me in the past and I have headr that may be part of the problem. I also had some problems when I had the quick change zif socket in the ecu. Hope this helps.
Old Sep 21, 2006 | 07:43 AM
Highvoltage's Avatar
I am dealing with this to,i just read a post elswhere and it ended up being a bad distibutor ,same solid cel and no spark,let us know what you figure out ..thanks
unknown0001
Nov 9, 2005 03:57 AM
impact_blu
Aug 18, 2005 01:36 PM
PHILLIPDEEZ
Aug 13, 2005 11:21 AM
Street Ghost
Jul 24, 2004 02:23 PM
South Bay Surfer
Dec 30, 2002 09:48 PM
