soldering to fix a radiator leak?
Old May 9, 2004 | 09:35 PM
dfoxengr's Avatar
Default soldering to fix a radiator leak?
has anyone ever heard of using solder to fix a tiny leak(hole) in an aluminum radiator.
Old May 9, 2004 | 09:43 PM
dfoxengr's Avatar
Default Re: soldering to fix a radiator leak? (hybridvteceg)
i found one thread on this, but it is useless.
the hole is near the fin. how about brazing? what is brazing, lol. thanks in advance
Old May 9, 2004 | 10:57 PM
dfoxengr's Avatar
Old May 10, 2004 | 12:27 AM
2+2=5's Avatar
the end tank are plastic and the fins are metal, once they have a leak, you can weld them shut all you want but they would last long with 1.1 bar of pressure pushing.
Old May 10, 2004 | 06:43 AM
dfoxengr's Avatar
Default Re: soldering to fix a radiator leak? (2+2=5)
im talking about all aluminum one.
Old May 10, 2004 | 07:25 AM
eLusive Acclude's Avatar
on the tanks you could heliarc but the core you'd have to solder, id just recommend replacing it
Old May 10, 2004 | 07:27 AM
nvmonkeys's Avatar
i had a leak in my accords radiator and i used jb weld and it didnt hold so then i used plumbers putty from home depot and its been holding for about a year now. so i guess u could try that. and i did put the plumbers putty over the cracked jb weld if that makes a difference.
Old May 10, 2004 | 07:34 AM
dfoxengr's Avatar
Default Re: soldering to fix a radiator leak? (nvmonkeys)
im going to solder, then RTV silicone over it and then a small piece of sheetmetal. ill let you know how it turns out
ballsack
Honda Motorcycles
Jan 13, 2007 09:37 AM
mrlegoman
Jan 14, 2006 01:01 PM
eastsideATX
Jul 6, 2005 02:56 PM
ID_ten_T
Sep 1, 2004 08:13 AM
BluLuder
Jul 29, 2002 11:29 AM
