smoking issue???!
Old Sep 22, 2002 | 06:12 PM
advanracing62's Avatar
Default smoking issue???!
Supposedly I have some smoke that comes out of my exhaust while speeding away from people, I did a compression test-OK, Leak Down- Better than 0%, I'm running Mobil1 5-30 and HAMP filter. MY cat is gone, my personal thought about what is wrong, and I've noticed a little louder than usual ticking coming from the valve train. Supposedly this smoke is blueish, while my tip in smoke is white. The car runs a bit rich as it backfires under decelleration. Any thoughts?
Old Sep 22, 2002 | 06:15 PM
Jared's Avatar
Default Re: smoking issue???! (advanracing62)
if you're running mobil 1 synthetic then its definitely not oil burning because synthetic wont smoke when it burns.
Old Sep 22, 2002 | 06:49 PM
Spankee2K's Avatar
Default Re: smoking issue???! (Jared)
thats not true at all...my friends 99 GSR ran full synthetic since day one and it smoked like crazy at about 30K miles.
Old Sep 22, 2002 | 07:35 PM
poison's Avatar
Default Re: smoking issue???! (PressurizedB18C5)
I am running Valvoline Syn 5w-30 in h22 and burns oil slowly.
I'm goign to switch to Mobil 1
Old Sep 22, 2002 | 07:38 PM
non-VTEC's Avatar
what do your plugs look like?
Old Sep 22, 2002 | 10:41 PM
Default Re: smoking issue???! (non-VTEC)
normal, no oil, no heavy carbon.
Old Sep 23, 2002 | 12:45 AM
aeolus's Avatar
Default Re: smoking issue???! (poison)
Just out of curiosity,how much oil is considered slow to u?.Im runnin an h22a also.It burns oil but no visible smoke as far as i can see....usually about half a quart every 1500 miles
Old Sep 23, 2002 | 06:27 AM
TimoneX's Avatar
New User
Default Re: smoking issue???! (aeolus)
If you're cat free there will be a bit more of a visible jet trail...er exhaust. Are you sure it's burned oil and not unburned fuel, a rich mixture?
Old Sep 23, 2002 | 07:45 AM
Default Re: smoking issue???! (TimoneX)
I havn't actually looked at the smoke yet. I was thinking that it had to do with the cat as well. I might have to try a cat that will work and see if that will help my situation. I don't have any oil consumption per se.....
Old Sep 23, 2002 | 08:12 AM
TimoneX's Avatar
New User
If it's only a little bit at the higher end of the rev range and you're running a straight pipe and not burning oil, I'd check my A/F ratio and or ignore it. Assuming the plugs are not getting fouled and the car is running fine with no codes.
Old Sep 24, 2002 | 09:15 AM
thanks, I just wanted some reassurance.
smoked08
19
Aug 30, 2011 09:23 PM
boostedjdmdc2
Jan 26, 2009 04:55 AM
ic108
Apr 16, 2008 05:07 AM
Honda97
Mar 10, 2005 05:06 PM
KiNG $h!t
Jan 28, 2005 08:50 AM
