Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: Why is Blue Smoke Coming Out of Tailpipe?
Guide to diagnose touble and recommended solutions.
Smoke coming out of exhaust
Ok well here's the deal my girlfriend has a 98 Honda civic ex auto well she accidently put alittle too much of oil in her car & didn't knw when we went to go out ,not even to corner it was smoking from exhaust so we decided to go bck home .I checked the oil & she had too much in there so I baught new oil filter & did an oil change & refilled it to where it needs to be. when you turn it on it'll still smoke a lot so I left it running for a bit then it wasnt smoking as much starting to jst smoke alittle then waited alittle bit then drove it like 20ft & it would barely smoke but when stop then give it gas it would smoke alittle,what do i need to do jst keep it running more till it blows all the bad smoke away?
Re: Smoke coming out of exhaust
The smoke is white ,motor sounds good after leaving it running for alittle bit . It wasn't smoking as bad it started to not smoke as much jst barely
How much is too much? Everytime I get an oil change they always put too much in maybe half up from the top line, never had a problem, but I burn a lot of oil anyway.
Well her car never burned oil...when we were going out the first time before I checked her oil. We were driving & there was a lot of white smoke coming out smelled like oil .we got to corner the turned & around drove back home. So I decided to do oil change lot of oil came out.. & when I put in the new oil. Turned on car it was still smoking then drove it around block & still smoking a lot . Got home left it running then the smoke stopped coming out as much.. but would smoke whenever I would be stopped then give it gas. Shld I turn on & let all that bad smoke go away
Sounds like her rings are going out. Once all the metal gets up to temp the clearances can change quite a bit. Just keep an eye on the temp gauge and check the oil level every once in a while. Unless you wanna pull the motor apart and do piston rings and valve seals..
So basically you were not driving that much with a lot of oil in it?
Sounds like there was a ton of oil in there, which way too much can be bad as too little oil.
Maybe you will get lucky since you caught it fast, and the rest will burn out the exhaust, just watch it for a few days.
When we got bck home the first time since driving it ,there was a lot of oil in there...! Lol
So that's why I went ahead & did oil change..& put in new oil.lol the motor isn't making no wierd noises or knocks sounds fine ,oil dipstick looks good & temp is fine as well,shld I jst keynote burn out the bad oil that was in there? Is it safe to drive on it?
Idk if every system in there was filled with oil wouldn't the motor start making noises ..bc i drove it earlier & it was driving fine nothing weird noises at all motor sounded good temp good oil good jst burning smoke out of exhaust
Ok well I jst started the car up.. & no more smoke coming out of exhaust I even accelerated it a bit & no smoke but I'm going to take it out for a drive later on & see how it does ill be make sure to let you guys knw!
that problem sounds like you probably flooded the engine just a tiny bit, like civic junkie and a few more people have told you, just drive it normally and it should burn out.
Yeah the smoke was white with alittle blue to it & well I drove it this afternoon & well its been doing good no more smoke at all but what I did notice when I was driving & when I'd make stops it would smoke alittle like from 1-10 I'd say a 2 barely ..but its slowly going away...so that's good it was a scare for my girlfriend.lol
Duhul
05-20-2010 11:18 AM
