SMOKING engine?
Old Oct 6, 2005 | 08:22 AM
marc-111's Avatar
Default SMOKING engine?
just came home from school and i opened the hood and opened the oil cap and white smoke was coming out from it? is it normal? or not?
plus when my car hits vtec a thick white/ light blue smoke comes out from it?
BTW the engine is a 95 B18c1 GSR
Old Oct 6, 2005 | 11:33 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: SMOKING engine? (marc-111)
Hmm, white smoke is bad. White smoke is coolant burning. Unfortunately, you probably have a blown head gasket. Does the smoke smell "sweet"?
Look at your oil, is it milky? You should do a compression/leakdown test to see if you are loosing compression.
Old Oct 6, 2005 | 05:37 PM
Redsun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 &raquo;</TD></TR><TR><TD CLASS="quote"> i opened the hood and opened the oil cap and white smoke was coming out from it? plus when my car hits vtec a thick white/ light blue smoke comes out from it?</TD></TR></TABLE>
You open your your oil cap whilst engaged in vtec? Cool!!!
Old Oct 6, 2005 | 09:55 PM
marc-111's Avatar
Default Re: SMOKING engine? (Redsun)
marc-111's Avatar
^^^^yo dumbass does my first post look like that one?!?!? that's why it's in the second line!!!! try taking ESL classes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marc-111 &raquo;</TD></TR><TR><TD CLASS="quote">just came home from school and i opened the hood and opened the oil cap and white smoke was coming out from it? is it normal? or not?
BTW the engine is a 95 B18c1 GSR</TD></TR></TABLE>
Old Oct 6, 2005 | 10:19 PM
marc-111's Avatar
Default Re: SMOKING engine? (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Hmm, white smoke is bad. White smoke is coolant burning. Unfortunately, you probably have a blown head gasket. Does the smoke smell "sweet"?
Look at your oil, is it milky? You should do a compression/leakdown test to see if you are loosing compression.</TD></TR></TABLE>
i already had my headgasket changed. My coolant level is not dropping. The smoke smells like gas.
i did a compression test. All 240 on all cylinders
Redprelude98
Nov 25, 2008 10:42 AM
9hatch6
Aug 5, 2007 06:29 PM
4drITR
May 3, 2006 09:13 PM
Nuke209
Dec 18, 2005 09:28 AM
B00STED Si
Feb 3, 2005 10:52 AM
