Smog: help
Old Mar 27, 2004 | 07:54 PM
Mr.Integra's Avatar
Default Smog: help
can't seem to pass it. Failed miserably. I have HC levels of 500+.
I'm thinking of running 2 cats, a carsound + stock. Has anyone tried anything like this?
Modified by Mr.Integra at 10:14 PM 3/27/2004
Old Mar 27, 2004 | 07:56 PM
Kal's Avatar
Kal
Default Re: Smog: help (Mr.Integra)
hi-flow cat might be a good option. Have you put your car through a tune up and stuff and what's been modified on your car?
Old Mar 27, 2004 | 09:13 PM
Mr.Integra's Avatar
bascially bolt ons with ITR cams + hondata
Before i had the cams and Hondata, i pass with flying colors even with the bolt ons.
I'm about to do a tune up on my car, but just wondering if anyone tried the double cat method
Old Mar 27, 2004 | 10:39 PM
hondatim's Avatar
has the hondata system been properly tuned? sounds like you may be tuned quite a bit rich. If factory cat is OK, a high flow cat is not needed as it won't make a huge difference if engine is that rich.
Old Mar 28, 2004 | 07:06 AM
Kal's Avatar
Kal
Default Re: Smog: help (hondatim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatim &raquo;</TD></TR><TR><TD CLASS="quote">has the hondata system been properly tuned? sounds like you may be tuned quite a bit rich. If factory cat is OK, a high flow cat is not needed as it won't make a huge difference if engine is that rich.
took the words out of my mouth
Old Mar 28, 2004 | 02:23 PM
Mr.Integra's Avatar
hondata has been tuned.. or so i thought..
i guess the guy who tuned it didn't really tune my idle
i checked the o2 sensor, and there was fuel on it!
so i'm probably running waay too rich at idle.
Old Mar 28, 2004 | 04:30 PM
Kal's Avatar
Kal
go yell at the guy
Old Mar 29, 2004 | 01:36 AM
Mr.Integra's Avatar
Default Re: Smog: help (Kal)
so during smog, is the hondata supposed to run closed loop with o2 sensor or be run open loop with a retuned map setting?
Old Mar 29, 2004 | 10:58 PM
hondatim's Avatar
Hondata should be tuned with no O2 feedback (open loop) and when tuning is done, O2 sensor should be reactivated in order to allow O2 feedback for closed loop operation.
Old Mar 30, 2004 | 08:10 AM
Propulsion's Avatar
high HC usually means you are running too rich, so look to lean it out a bit.
Old Mar 31, 2004 | 06:48 PM
Mr.Integra's Avatar
Default Re: Smog: help (SilverCIVIC96)
okay. went back again. added 3 bottles of HEET to 1/2 tank of gas. Timing's at 16 degrees.
HC is 250 this time.
CO is also a bit high, forgot the numbers.
NOx dropped from 1000 to 150.
maybe bad catalytic convertor? how can you tell that the cat is bad?
Old Mar 31, 2004 | 08:48 PM
h2392si's Avatar
ive got a smog hook up , but its in rialto. let me know,peace.
Old Apr 1, 2004 | 12:43 PM
2000lss's Avatar
Default Re: Smog: help (h2392si)
hey guys, i'm in the bay area too and gonna have my smog in oct and i was wondering how did they do ur? did u have to go to the Test only station or just went to one of those gas stations? i'm hearing mix answers, some saying u get radomly pick for test only station and some saying u have to go to test only station. And what year integ do u have? cause i hear that if u have obd2 integs, they scan ur ecu and if it's not the right one, u fail! i'm coverting to obd1.
Old Apr 14, 2004 | 01:32 AM
MugenAccordSedan's Avatar
where's rialto? i just got a 95 accord with a H22a and a serious amount of bolt-ons. I've researched this site about smog and all the **** that comes with it in CA and am scared i won't pass. California smog laws suck *****.
lazy dp
Aug 14, 2008 02:43 PM
tomlinson619
Jul 19, 2006 12:29 AM
totsie7944
Jul 7, 2004 03:29 PM
Project92Hatch
12
Oct 17, 2003 08:33 AM
NSX Bob
May 5, 2003 03:38 PM
