slightly black pistons
Old Mar 20, 2005 | 03:59 AM
nbintegracing00's Avatar
Default slightly black pistons
i just pulled my head of my car and my piston head have black on them that i cant really rub off any ansers to why this might be it used to have nos but i didnt really use it much
Old Mar 20, 2005 | 04:18 AM
B20TDC2's Avatar
Default Re: slightly black pistons (nbintegracing00)
probably just carbon buildup. are there any signs of detonation?
Old Mar 20, 2005 | 05:39 AM
N20civicB18's Avatar
well i would belive the nitrous would of made it burn hot enough to burn the carbon out.... Kent makes a spray that is called carbon and gasket remover if you can find that (I have it at work at a ford dealership) and anyways spray that stuff on and wait a minute and the carbon is lifting off but break clean will work alright too. change your oil after. why it might be? running rich, not opening it up enough, is it burnt oil? could be alot of things
Old Mar 20, 2005 | 02:02 PM
Default Re: slightly black pistons (N20civicB18)
i have no clue it used to burn a little bit of oil but i had a couple bad valve seals
nrraiders35
Apr 24, 2013 06:48 AM
notguilty411
Jul 31, 2005 05:40 PM
Shizznaz
Apr 17, 2005 10:52 AM
benjaminenjamin
Dec 5, 2004 04:53 PM
ASSASSIN
Sep 24, 2004 04:50 PM
