sleeving a ls and b20 block whats the difference
Old Mar 1, 2007 | 11:09 AM
eighty three's Avatar
Default sleeving a ls and b20 block whats the difference
i was wondering if anybodu new what was the difference between sleeving a ls block and sleeving a b20 block if there is any difference
Old Mar 1, 2007 | 08:52 PM
2point0VTEC's Avatar
Default Re: sleeving a ls and b20 block whats the difference (jdmhooks)
same ****...b20=overbored LS
Old Mar 2, 2007 | 03:41 AM
blackeg's Avatar
Default Re: sleeving a ls and b20 block whats the difference (2point0VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point0VTEC &raquo;</TD></TR><TR><TD CLASS="quote">same ****...b20=overbored LS</TD></TR></TABLE>
ummmm
a sleeved ls will be much stronger than a stock b20. the sleeves are completely different material.
Old Mar 3, 2007 | 03:57 PM
RACINTWEEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhooks &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if anybodu new what was the difference between sleeving a ls block and sleeving a b20 block if there is any difference</TD></TR></TABLE>
to answer your question
LS and B20 blocks have totally different sleeves. the LS has four individual sleeves with more(compared to a b20) wall thickness. B20's have one big sleeve that contains all 4 cylinders, they are also set into the block differently than the standard b-series ones.
since it sounds like you are planning on sleeving a motor and havent decided which one, i recommend an LS: 2 reasons why, LS block would be much cheaper to buy than a B20 block, and will be slightly cheaper to have sleeved than a b20 block.
Old Mar 3, 2007 | 09:54 PM
Bense's Avatar
since you're in CA, go with the sleeved LS. good luck with the emissions with the b20!
Old Mar 5, 2007 | 08:21 AM
Golden Eagle's Avatar
Default Re: sleeving a ls and b20 block whats the difference (RACINTWEEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACINTWEEK &raquo;</TD></TR><TR><TD CLASS="quote">to answer your question
since it sounds like you are planning on sleeving a motor and havent decided which one, i recommend an LS: 2 reasons why, LS block would be much cheaper to buy than a B20 block, and will be slightly cheaper to have sleeved than a b20 block.</TD></TR></TABLE>
yes i would sagest the b18, they are cheaper to buy and cheaper to sleeve and when your done if you take the b18a/b to 84mm it will be a 2.0 and just to let you know we sell b18a/b sleeved blocks for 950.00 shipped
civdx94
Aug 6, 2005 08:12 AM
nvmyb20hatch
Nov 20, 2004 04:18 PM
nvmyb20hatch
Nov 20, 2004 02:01 PM
BI8B
Feb 24, 2004 09:46 AM
