Skunk2 pro VS Golden Eagle Cam Gears (which better)
Skunk2 pro VS Golden Eagle Cam Gears Vs BDL (which better)
ok im in the market for a set of cam gears for a built motor that im currently doing.. Tuning will be done obvioiusly so im going to up grade my cam gears. Ive been looking 2ward these three designs/companys. Ive heard good from both but which do u guy sugest considering u might have experience with them..(any issue with slipage etc)
BDL
Skunk2 Pro serious cam gears
Golden Eagle cam gears
Modified by EM1OwnerSi at 8:16 PM 3/21/2007
BDL
Re: Skunk2 pro VS Golden Eagle Cam Gears Vs BDL (EM1OwnerSi)
I'm not sure if theres a better one. I guess if you think more bolts is better then the bdl and skunk 2 is for you. I like the GE myself.
its all about the fasteners. thats why i choose crower, which uses arp.
although, out of those listed above, i've had no problem at all with the sk2 pro cam gears. besides, they like tight
Re: (gsrious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious »</TD></TR><TR><TD CLASS="quote">its all about the fasteners. thats why i choose crower, which uses arp.
although, out of those listed above, i've had no problem at all with the sk2 pro cam gears. besides, they like tight </TD></TR></TABLE>
we make the crower gears but these are all good gears
Banned
Re: (Golden Eagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle »</TD></TR><TR><TD CLASS="quote">
we make the crower gears but these are all good gears </TD></TR></TABLE>
Yup!
Skunk2... but I work there so I'm bias.
These are all good gears. What ever you decide you'll have a quality pc.
Yup!
i perfer the crower/golden eagle cams gears just for the fact that the bolts they use are actual bolts and not stupid *** allen key heads that always strip out.
try adjusting those skunks when the engine is hot as hell with a tiny allen key......guarenteed you are gonna strip the **** out of it if you are not carful.
Banned
Re: Skunk2 pro VS Golden Eagle Cam Gears Vs BDL (non-VTEC)
Well if your a Rock Ape and you dont know how tight is tight... your gonna strip them out! We are subject to the same conditions as you are and we dont have these problems.
Cam Gears are not meant to be played w/ as much as you are suggesting anyhow! You can set cams (according to the cam card) and never touch them again.
