Skunk2 Cam Timing with a Stroker Kit
To get started Im building a NA B18C1. The skunk2 stg 2 cams say 108' in and 54' ex, with stock stroke at the TDC. Im uping the stroke to 95mm and need to know what angle should they be set to with the new stroke? Does anyone know or is there some webpage thats got a stroker kit timing diagram?
You cant just set it some where. The cams are going to have to be degreed.
http://www.skunk2.com/camshaft_tech.php
This will help you out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Power »</TD></TR><TR><TD CLASS="quote">To get started Im building a NA B18C1. The skunk2 stg 2 cams say 108' in and 54' ex, with stock stroke at the TDC. Im uping the stroke to 95mm and need to know what angle should they be set to with the new stroke? Does anyone know or is there some webpage thats got a stroker kit timing diagram?
I'm not sure what "108' in and 54' ex" means but if your looking for cam centerlines, they are 94* ATDC intake and 112* BTDC exhaust. Degreeing you cams and using these centerlines will insure you have set the cams up properly, regardless of your bottom-end configuration.
</TD></TR></TABLE>I'm not sure what "108' in and 54' ex" means but if your looking for cam centerlines, they are 94* ATDC intake and 112* BTDC exhaust. Degreeing you cams and using these centerlines will insure you have set the cams up properly, regardless of your bottom-end configuration.
DA9TEG305
Mar 29, 2006 09:14 AM
94IntegraLs04
Feb 27, 2005 12:49 PM
