Skunk2 Cam Gears - Quick Question
Old Mar 30, 2003 | 12:19 PM
7rrivera7's Avatar
Default Skunk2 Cam Gears - Quick Question
Can someone tell me how many degrees each mark is on these cam gears?
Thanks!
Old Mar 30, 2003 | 01:28 PM
dfoxengr's Avatar
Default Re: Skunk2 Cam Gears - Quick Question (7rrivera7)
[Modified by hybridvteceg, 6:12 PM 3/30/2003]
Old Mar 30, 2003 | 01:52 PM
7rrivera7's Avatar
Default Re: Skunk2 Cam Gears - Quick Question (hybridvteceg)
Are you sure? Their website says the gears mark +10/-10 and there are 5 marks on either side of the center mark. Wouldn't this mean each mark = 2 degrees?
Old Mar 30, 2003 | 02:12 PM
dfoxengr's Avatar
then dont ask..good job u found it urself
Old Mar 30, 2003 | 02:28 PM
MikeSarr_GSR's Avatar
buy another gear. next question?
here is a fun way to see it in real time, y0. set your distributor timing to 14BTDC at 0 on the intake cam. set the cam gear at plus 1 on the gear, you will be at 16BTDC without reclocking the distributor. I actually use this method to make sure I know how far I have advanced the gear, I lock it down where I want it, then chase timing after I have the setting I want
[Modified by MikeSarr_GSR, 11:31 PM 3/30/2003]
Old Mar 31, 2003 | 03:48 PM
7rrivera7's Avatar
Default Re: Skunk2 Cam Gears - Quick Question (MikeSarr_GSR)
Why buy another gear? What are you actually saying? Skunk2 gears are lame?
Old Mar 31, 2003 | 04:16 PM
they are just inconvenient to use in IMO. the fasteners are right on top of the etch marks which become hard to see after a while. not to mention the backing plate is made of aluminum which is soft metal. any amount of over-tightening will strip them over time. I want a -10/+10 gear thats more robust for my next set.
TopGear_
Aug 18, 2008 09:56 AM
VRD^suzie
Apr 25, 2007 01:32 PM
HybridIntegra
Apr 7, 2005 04:13 AM
lilredhatch
Mar 5, 2004 07:45 PM
See Are X
Feb 13, 2003 09:29 AM
