skunk 2 stage 3's on the street?
Old Feb 21, 2003 | 12:19 PM
warwagon's Avatar
Default skunk 2 stage 3's on the street?
anyone do it or has neone seen it done
good or bad?
Old Feb 21, 2003 | 12:30 PM
gsrvx's Avatar
New User
Default Re: skunk 2 stage 3's on the street? (warwagon)
PM Allmotormadness
If i recall correctly...he's running em
-Rod
Old Feb 21, 2003 | 12:33 PM
evilxkid's Avatar
ya i'm running them and they run fine. i'v been running them for a year. they idle good too.
Old Feb 21, 2003 | 01:55 PM
skunked's Avatar
Yep....No Problem.
Old Feb 21, 2003 | 02:30 PM
VTECorona's Avatar
Default Re: skunk 2 stage 3's on the street? (skunked)
How about inspection (NJ is **** with emissions)? What else do you have to upgrade on the valvetrain with the 3's?
Old Feb 21, 2003 | 02:37 PM
57one's Avatar
Default Re: skunk 2 stage 3's on the street? (97RedTegGSR)
Anyone dynoed yet with skunk2 stage 3's?
Old Feb 21, 2003 | 02:46 PM
lazy bum shaughn's Avatar
Default Re: skunk 2 stage 3's on the street? (57one)
What kind of valvesprings and retainers are you running? Skunk2?
What about fuel management?
Old Feb 21, 2003 | 03:55 PM
Phaze2 Mike's Avatar
Default Re: skunk 2 stage 3's on the street? (lazy bum shaughn)
From what i have seen and heard from frineds running aftermarket valvetrain, people usually get the best results (and have less problems) if they stick the brand valvetrain that the cams are (Skunk2 3s with skunk valvetrain)
Old Feb 21, 2003 | 04:04 PM
silverCRXTC's Avatar
Default Re: skunk 2 stage 3's on the street? (Nextekhatch)
since im continplatining skunk2 stage 2, should i just get the 3s? how is the midrange on these cams? is the power band nice or is it like slow as ***** then bamb! insane power or is it a nice moderate gain?
i ask alot of questions !
Old Feb 21, 2003 | 04:05 PM
warwagon's Avatar
from what i have researched today i have found that you have to have some serious flow through the head so i think i am gonna stick with the stage 2's and the skunk valvetrain. As far as the 2's do they scream when vtec hits?
Old Feb 21, 2003 | 04:15 PM
yeah u need skunk springs (espicially on a first gen) the stage 1s can work with a stock vavle train, but y risk a motor, im doing the whole 9 yards, i wounder if i should also go skunk2 valves?
Old Feb 21, 2003 | 04:25 PM
evilxkid's Avatar
Default Re: skunk 2 stage 3's on the street? (silverCRXTC)
i use crower retainers with mine. they work great.
Old Feb 21, 2003 | 07:58 PM
rolow's Avatar
Default Re: skunk 2 stage 3's on the street? (evilxkid)
i have not problems running mine on the street.
I am running an all skunk2 head.
I would not run these if you are not running atleast 12.5:1 or plan on upgrading to the comprestion level in the near future.
I tried them running a very low comprestion and lost 10 foot pounds and made 0 Hp. Compared to skunk2 stage 1's
[Modified by rolow, 8:58 PM 2/21/2003]
Old Feb 21, 2003 | 08:52 PM
InevitableRace's Avatar
Default Re: skunk 2 stage 3's on the street? (rolow)
On the Skunk2 stage 3 Cams what's the Vtec cross over kick in at???
Ross
Old Feb 21, 2003 | 08:53 PM
rolow's Avatar
Default Re: skunk 2 stage 3's on the street? (allmotrb18c1)
5800rpm
Old Feb 21, 2003 | 08:56 PM
On a 1.8L or a 2.0L???
Ross
Old Feb 21, 2003 | 09:14 PM
warwagon's Avatar
so 12.0cr is not enough compression to run them, and will the ctr head flow enough
Old Feb 21, 2003 | 09:35 PM
rolow's Avatar
I relly don't know! Every thing I have read says 12.5 + min.
Ross
B20 vtec
[Modified by rolow, 10:35 PM 2/21/2003]
Old Feb 21, 2003 | 11:39 PM
warwagon's Avatar
i am runnin a ls/vtec 1.8L just 20 over so i got a set of brand new stage 2's for $450, i will prolly just run those the way i have been hearing!!!
Old Feb 22, 2003 | 06:30 AM
I dont understand why you will lose torque and power if you dont have high compression with cams.
Old Feb 22, 2003 | 08:26 AM
TimoneX's Avatar
New User
Because more aggressive cams have a later valve closing after bottom dead center(ABDC). This allows the pistons to force some intake charge back out of the CC prior to ignition, reducing your dynamic compression. Increasing your static compression gets you some of that back. Try this:
http://www.rbracing-rsr.com/comprAdvHD.htm
You have to enter alot of info, but the results can be astounding. Just a degree or 2 increase in your intake cam's ABDC can drop your dynamic compression dramatically. This and cost is precisely why I went with Crower 63403 cams w/ an ABDC of 46. For reference I believe CTRs are 45 and skunk2 stg2s are 49. This will cost you low end power unless your run a high compression.
Silvertc
Apr 17, 2008 08:52 PM
bigz187
Jun 11, 2005 07:22 AM
Nov!ce
Jan 3, 2005 09:08 AM
H22aInside
13
Oct 14, 2003 07:21 PM
