Silent valve damage???
Old Feb 27, 2017 | 04:10 PM
Efabe's Avatar
Default Silent valve damage???
97 Accord EX F22B1...Heres the situation, the timing belt broke at highway speed and I had it towed back to my place. I replaced the timing belt, water pump, and tensioners hoping for the best but when I fired it up, it ran like crap. Noticeable misfires but no CEL and zero valve noise. Can the valves be bent/damaged but not making any excess noise? Or is there a chance I didn't set the timing belt right? which leads me to my next question. Does it matter which stroke the cam or crank is on?Or is TDC the same regardless? Because I know the marks were lined up.
Old Feb 27, 2017 | 06:25 PM
Efabe's Avatar
Default Re: Silent valve damage???
UPDATE. Having nothing to lose and assuming that I didn't install the timing belt in the right position, I pulled the key from the cam pulley, rotated the crank 1 full turn, reinserted the key and installed the bolt. Still missin like hell so I'm guessing the valves are toast
Old Feb 27, 2017 | 08:56 PM
v4lu3s's Avatar
RTFM
Leakdown test or pull the head
Old Feb 27, 2017 | 08:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Do a compression test.
Old Feb 28, 2017 | 07:51 AM
Efabe's Avatar
Cylinder 4 has a healthy 125 psi, cylinders 1,2,3 on the other hand all made 0 psi. Considering those numbers, I would say it actually ran pretty good but the valves must not be closing all the way on 1,2 and 3 so the head will be inevitably be coming off. Let this be a lesson to anybody who doesn't think a small oil leak is a big deal or to the people trying to save a few bucks on the timing belt kit by getting one w/o crank/cam seals. Even a small amount of oil on the timing belt IS a big deal and could cost you a motor.
ekdriver707
Dec 4, 2013 05:01 AM
BONNARSKI
Dec 21, 2011 09:26 PM
BobS95v6
Mar 21, 2011 07:01 AM
AaronJ
Feb 10, 2009 07:48 PM
ampm
12
May 3, 2007 10:53 PM
