Should I be concerned about the coating on this head?
Old Jul 28, 2015 | 08:23 AM
SonicXtasy's Avatar
Default Should I be concerned about the coating on this head?
Hi guys. New to the forum and have some some questions about a motor swap I am doing. I just picked up a 98 Integra RS manual from my neighbor for $600 for my son. It has 265K on it and I was told it had a bad head gasket. I did not want to bother with a head gasket on a motor with such high miles so I decided to just replace the motor. Knowing most B18's would have been beat on most their life I decided getting a JDM B20 was a better option, less likely to be beat on and should have slightly more power. (a 17 year old does not need a vtec swap, lol). I bought the car 2 days before taking a short vacation to Orlando and while there purchased what I was told was a lower mileage 99 JDM B20B from an importer that was recommended to me. I also ordered an OEM water pump, oil pump (that can hold a crank sensor), timing belt and tentioner. Also picked up valve cover and oil pan gaskets and new motor mounts. When I took off the valve cover of the new engine I noticed to did not look as i thought it would look. There is almost a coating of old oil or something on the head. Is it normal or something I should be concerned about? The original looked clean, like I thought it should look. Any input would be great. Thanks.
Old Jul 28, 2015 | 08:56 AM
1991_crxsi's Avatar
Default Re: Should I be concerned about the coating on this head?
That is normal, just a little oil residue. You should see the inside of one of the engines I ordered from Japan.... looked about like this but I didn't take a pic
Old Jul 28, 2015 | 12:53 PM
SonicXtasy's Avatar
Thanks, that gives me some reassurance. Did they ever change the oil in that motor in the pic?
Old Jul 28, 2015 | 02:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The darker "bronzing" inside that you have in that picture is from extended oil change intervals. I don't see a lot of "build up" of sludge or residue present and that is a good sign. The color is representative of an owner that didn't do routine maintenance quite as often as they should have... but did a pretty good job. The pic of the single cam head below your post shows just plain neglect.
You should be fine based on the pics above.
Old Jul 28, 2015 | 03:48 PM
1991_crxsi's Avatar
Great, you should be good to go... and no, they probably never changed the oil in the above pic, but then again you never know.
Old Jul 28, 2015 | 05:33 PM
v4lu3s's Avatar
RTFM
that does not look like lower mileage to me at all. its either high mileage or like said before poor oil change practices. I have never bought an imported engine that looked that worn so far, but I have only bought four or five...and the cylinder head in my original 250k mile engine looked better than that.
Fairtax4me
Mar 17, 2014 07:21 PM
ludesrv
Honda CR-V & Element
13
Feb 28, 2014 05:00 AM
Coomer
Aug 20, 2008 08:23 AM
spaceman
May 14, 2004 12:09 PM
Gir
26
Jun 16, 2003 06:09 AM
