Shortblock teardown / assembly (H22)
Old Aug 28, 2009 | 12:42 PM
dagle's Avatar
Default Shortblock teardown / assembly (H22)
I've taken shortblocks apart and put them back together before with no trouble. Albeit it's time consuming, but its not by any means difficult. My question is for completely new bearings, is there a way to DIY install? this is for the main rod bearings, everything else should be as straight forward as I recall. I'm getting ready for a new motor, and figured I would ask before I attempt it myself or pay a shop to do it.
H22A
AEBS sleeves w/ 87mm bore
JE 9:1 pistons in 87mm bore (std)
pauter rods
fresh crank
cliff questions:
-How do I go about installing/replacing the bearings?
-Is it okay to re-use the ARP rod bolts?
-If it can't be DIY, how many hours of labor to get the bearings on would it be and what should i ask the shop/lookout for?
thanks in advance
Old Aug 29, 2009 | 05:54 AM
street_ride14's Avatar
Default Re: Shortblock teardown / assembly (H22)
take oil pan off, oil pickup off, windage tray off, crank girdle off, oil pump off, flywheel off, flywheel cover that's attached to block off, rod bolts off, crankshaft off .... then you get to all bearings .... replace with new bearings, reinstall in reverse. Make sure everything is within spec.
Old Aug 29, 2009 | 08:13 AM
VEGAN_EG's Avatar
Yeah its pretty straight forward.
nothing to specific to h22 minus the torque specs.
Old Aug 29, 2009 | 10:44 AM
dagle's Avatar
dont the bearings have to be pressed in or shotpeened? sorry that was mainly the original question, im somewhat familiar with the rest.
Old Aug 29, 2009 | 12:47 PM
onthe3rdday's Avatar
No press, no shotpeen. You are overthinking it.
Old Aug 8, 2011 | 07:10 AM
cjh4l22's Avatar
bringing this back from the dead...
But, besides using plasti-guage, how do you go about measuring the crank, rods and piston rings to make sure they are within spec?
Old Aug 8, 2011 | 07:26 AM
kyden's Avatar
bore gauge and micrometer. with rings its fairly simple, just need a feeler gauge. though i would not reuse rings.
Old Aug 8, 2011 | 10:04 AM
cjh4l22's Avatar
Any chance you can describe those a little? and Yea, no plans in re-using rings.
TravisBiggie
Apr 10, 2013 08:21 AM
bmiller17
Nov 16, 2006 06:41 PM
Sinner
May 15, 2003 04:48 PM
HotWheelz
Nov 2, 2002 10:01 AM
B20zvtecek
Oct 28, 2002 07:11 AM
