Shop costs to replace rings?
Old Sep 26, 2006 | 09:58 PM
Mugen112's Avatar
Default Shop costs to replace rings?
How much is it usually to get a shop to hone out and replace all 4 piston rings and put the enigne back together?
Old Sep 26, 2006 | 11:38 PM
BuddhaSiR's Avatar
Default Re: Shop costs to replace rings? (Mugen112)
What kind of car? what engine?
Old Sep 27, 2006 | 10:03 AM
Mugen112's Avatar
1995 obdI jdm b18c gsr motor in a 1993 honda civic coupe
Old Sep 27, 2006 | 10:04 AM
EJ1 wilcox's Avatar
Default Re: (Mugen112)
I don't even want to know. Probably at least a few thousand.
Old Sep 27, 2006 | 10:22 AM
ST4TUS's Avatar
Default Re: (EJ1 wilcox)
interested in the cost for the change of rings, possibly valve seals.(b18c1)
Old Sep 27, 2006 | 10:35 AM
BuddhaSiR's Avatar
Default Re: (1MPOUND)
According to ALLDATA labor guide. Calls for 10.8 hours. This includes remove and install cylinder head and oil pan, hone cylinder walls, and plastigage bearings. My labor rate is $65 per hour. Labor only would be $700.
Old Sep 27, 2006 | 10:58 PM
BoostedJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">I don't even want to know. Probably at least a few thousand. </TD></TR></TABLE>
you sir are an idiot. don't poke your head in things you dont know.
depending on which labor guide you are going by, it calls for 9.5 to 11 hours. With 70ish being the average labor rate these days, you are looking at anywhere from 650-700. Most wont charge this much.. but its best that you remove the head and take them a simple shortblock... might save you some cash in the end
Old Sep 28, 2006 | 06:51 AM
EJ1 wilcox's Avatar
Default Re: (BoostedJeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff &raquo;</TD></TR><TR><TD CLASS="quote">you sir are an idiot. don't poke your head in things you dont know.
Yup, I'm an idiot.
Actually, I would call someone who has to pay to have someone to work on their car an idiot.
I've heard quotes on head gaskets alone that were over $1000. I figured that since installing new rings requires quite a bit more work than a simple head gasket that it would cost more.
But what do I know? I build all my own engines and do all my own work.
Old Sep 28, 2006 | 07:03 AM
so lazy's Avatar
i charge a flat rate of $600 thats me take your engine out tear it apart... hone the block for the knew rings.. new rod bolts.. head gasket, valve cover seal,(all parts included in price.. i tend to ask the customer if they would like for me to replace their rear main,crank seal, cam seals, water pump, timing belt while i have it out.. (this is free of labor as long as you buy the parts)
Paul Kane
K Series
Jun 8, 2015 05:49 PM
Thewavyboy
Northeast
Aug 19, 2013 03:26 PM
butch1175
Feb 12, 2013 06:06 PM
Type-Rare#1248
Mar 12, 2003 11:10 AM
J T*
Feb 22, 2002 03:05 AM
