shifter gets stuck in gear at high rpm's
Old Oct 30, 2006 | 05:39 PM
vtec25's Avatar
Default shifter gets stuck in gear at high rpm's
What is that? i heard about grind going into a gear or not going into gear and i know thats a synco problem. But my shifter at high rpm's gets stuck in gear till the revs drop alittle. what could this be?
Old Oct 31, 2006 | 01:01 AM
vtec25's Avatar
Default Re: shifter gets stuck in gear at high rpm's (vtec25)
bump
Old Oct 31, 2006 | 05:30 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
bump mine get's stuck in 5th if i drive it in that gear for more then 5 min's w/o shifting i have to roll the car back to get it out
Old Nov 1, 2006 | 12:13 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: shifter gets stuck in gear at high rpm's (DBL)
Sounds like you need a new clutch.
Old Nov 1, 2006 | 05:13 AM
loudassVTEC's Avatar
Default Re: shifter gets stuck in gear at high rpm's (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you need a new clutch. </TD></TR></TABLE>
That's what I was thinking. Throw-out bearing, or shift fork is what I'm thinking.
Old Nov 2, 2006 | 04:46 PM
vtec25's Avatar
Default Re: shifter gets stuck in gear at high rpm's (loudassVTEC)
ya got my head working alittle. do ya think its the slave cylinder?
Old Nov 3, 2006 | 02:16 PM
I guess it could be the slave cylinder. Here's what you do. Get into 5th gear, and when you want to come out, blip the throttle, and try to pull the tranny out of 5th. As the engine switches from loaded to unloaded, it should come right out with no problem. If it comes right out of gear, then you know you have a clutch problem, because the clutch isn't engaging.
Old Jan 21, 2007 | 07:06 AM
bouncer514's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec25 &raquo;</TD></TR><TR><TD CLASS="quote">What is that? i heard about grind going into a gear or not going into gear and i know thats a synco problem. But my shifter at high rpm's gets stuck in gear till the revs drop alittle. what could this be?</TD></TR></TABLE>
Same story here, my master + slave cylinder + clutch, including the throwout bearing of course, had been replaced this week and I STILL get the exact same problem. All gear are stuck at over 2500rpm which is frustrating. pls help !
Old Jan 21, 2007 | 07:16 AM
bart2546's Avatar
Default Re: shifter gets stuck in gear at high rpm's (bouncer514)
Well from what I understand, a lot of honda trannys have double synchromeshes. My car is a 99 EX. If I say I start out driving and just take the RPMs up to about 5.5 or 6.5k, trying to shift from 1st to 2nd hard and fast will almost never happen, it's like I'm missing a gear but it just won't let it go into the 2nd gear. Basicially from my research that I've looked around, it's just that due to the double synchromesh, they are unable to keep up with the speed of the engine RPM's so when you try to shove it into another gear they don't mesh. Not really anything you can do about it unless you wanna mess with tranny work (which I personally have NO experience with) but also from what I understand it's not something that is BROKEN, just the way the tranny is made.
Old Jan 21, 2007 | 04:28 PM
davidluko's Avatar
Default Re: shifter gets stuck in gear at high rpm's (bart2546)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bart2546 &raquo;</TD></TR><TR><TD CLASS="quote">Well from what I understand, a lot of honda trannys have double synchromeshes. My car is a 99 EX. If I say I start out driving and just take the RPMs up to about 5.5 or 6.5k, trying to shift from 1st to 2nd hard and fast will almost never happen, it's like I'm missing a gear but it just won't let it go into the 2nd gear. Basicially from my research that I've looked around, it's just that due to the double synchromesh, they are unable to keep up with the speed of the engine RPM's so when you try to shove it into another gear they don't mesh. Not really anything you can do about it unless you wanna mess with tranny work (which I personally have NO experience with) but also from what I understand it's not something that is BROKEN, just the way the tranny is made. </TD></TR></TABLE>
So basically what you're saying is, Hondas were made with high RPM redlines but their trannies were designed to not be shifted above 5k RPMs?
Old Jan 21, 2007 | 05:45 PM
b16a4's Avatar
try replacing the other bearings in the gearbox
there 5 of them
mwr1964
Nov 19, 2010 11:36 AM
lumnite
Dec 9, 2009 06:29 PM
5Point7Liter
Mar 16, 2007 07:52 AM
onyx00
Feb 25, 2005 11:45 AM
Bond
Jan 31, 2005 07:14 PM
