shift light wiring
Old Jul 28, 2003 | 06:26 PM
I3iggy's Avatar
Default shift light wiring - accuracy?
i just got a shift light for my car (95 del sol vtec), and i was wondering about the wire that you have to run to the coil. i was thinking about tapping into the wire closer to the dash rather than running a whole new wire from the coil. but my brother said that he heard it makes it more innacurate (approx 50-100rpm) if you do that. so i was wondering if this is true? preferably, i would like to run a wire from the factory tach into the shift light. is that possible either?
Modified by I3iggy at 7:47 PM 7/28/2003
Old Jul 28, 2003 | 06:33 PM
Mohudsolo's Avatar
Default Re: shift light wiring (I3iggy)
My Integra has a blue wire near the master cylinder that is an external tach signal hookup. It is there to allow for testing rpm's without having to connect to the internal coil. I have my shift light hooked up to it. I think the wire and location is common to other Hondas. The wire ends in a standard connector which has a cover in it and is taped over to keep the cover in.
Old Jul 28, 2003 | 06:38 PM
I3iggy's Avatar
Default Re: shift light wiring (Mohudsolo)
yeah, i know where to hook it up under the hood. im just wondering if it looses its accuracy if you hook it up to your tach instead. i want to keep my engine bay looking as clean as possible, but i dont want to loose the accuracy. if the shift light engages 200rpm after its supposed to, that could cause lots of problems.
civic-one
Mar 11, 2013 04:28 PM
keith1054
Feb 21, 2009 11:23 AM
HandicapRacer
Jun 24, 2006 06:12 AM
Sir Del Slow
Apr 28, 2003 09:49 PM
SiZ
Apr 11, 2003 02:32 PM
