shift light installation? help! please!
Old Dec 27, 2003 | 05:38 PM
92civeg's Avatar
Default shift light installation? help! please!
I recently bought and installed a proform shift light. Coming from the light I ran the green wire to the blue wire (tach signal wire on eg's) and for the power i just hooked it up to my 15 amp radio fuse and then grounded it and set it to 8100 rpm's. Although pretty often when im driving the light starts to flicker and i don't know why..the light does work when i reach 8100 rpm's... i just cant figure out why it flickers????
Old Dec 27, 2003 | 09:56 PM
92civeg's Avatar
Default Re: shift light installation? help! please! (92civeg)
ttt
Old Dec 27, 2003 | 10:11 PM
gumbii's Avatar
how do you hook it up to 8100....
or how do you install one of those...??
what wire do you tap into...??¿
Old Dec 28, 2003 | 09:14 AM
92civeg's Avatar
Default Re: (gumbii)
ttt
Old Dec 28, 2003 | 09:47 AM
RCautoworks's Avatar
I have heard a lot of people having this problem with the proform light. People say it flickers every now and then at idle, I would make sure all your connections are good and your ground is good.
Old Dec 28, 2003 | 09:51 AM
92civeg's Avatar
Default Re: shift light installation? help! please! (90blackcrx)
Yeah, it does happen at idle the most. Ill recheck my connections to be sure though.
Old Dec 28, 2003 | 07:03 PM
Kelly.'s Avatar
I've quit using this account
mine also flickers every now and then,
i just got used to it
Old Dec 28, 2003 | 07:26 PM
doublejz's Avatar
Default Re: (llewsirc)
try another spot for the ground wire.
Old Dec 29, 2003 | 08:47 PM
fxrob's Avatar
Default Re: (doublejz)
Mine flickers at idle also....I've tried 2 different ground locations and it didn't help. It's annoying, because I have to keep the damn cover on the light all the time. Should have bought the Autometer one I guess. Proform
Old Dec 30, 2003 | 02:23 PM
Default Re: (fxrob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fxrob &raquo;</TD></TR><TR><TD CLASS="quote"> Should have bought the Autometer one I guess. Proform </TD></TR></TABLE>
Autometer makes proform.
Old Dec 30, 2003 | 02:43 PM
mattssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg &raquo;</TD></TR><TR><TD CLASS="quote"> Coming from the light I ran the green wire to the blue wire (tach signal wire on eg's) and for the power i just hooked it up to my 15 amp radio fuse and then grounded it and set it to 8100 rpm's.</TD></TR></TABLE>
You didn't just loop the wire around one of the fuses did you?
civic-one
Mar 11, 2013 04:28 PM
vthree
May 6, 2006 03:56 PM
clutch33
May 27, 2004 08:12 PM
trutuner
May 25, 2003 06:37 PM
Sir Del Slow
Apr 28, 2003 09:49 PM
