Shift knob gram differences
Old Nov 29, 2003 | 01:05 PM
spacekid987's Avatar
Default Shift **** gram differences
Can anyone tell me if it's better to get a new shift **** that weighs 143g or 400g? Thanks!
Old Nov 29, 2003 | 02:53 PM
Default Re: Shift **** gram differences (spacekid987)
It's going to be a gift and I need to know which one is better. I'm guessing the lighter it is the better, right? hello....anyone........
Old Nov 29, 2003 | 03:05 PM
AL ASPIRATED's Avatar
i rather go with a heavier shift ****, better for fast shifting
Old Nov 29, 2003 | 03:53 PM
Is it! Well there is one that I was looking to purchase and it's 400g and there's the other ones for 200g and 300g. So I should purchase the one for 400g! right? I really don't know much about this stuff, so thanks!
Old Nov 29, 2003 | 04:07 PM
Any advice will help because it's going to be for someone special and it has to be perfect. Thanks!
Old Nov 29, 2003 | 04:15 PM
EJ1 wilcox's Avatar
The reason that some shift ***** are heavier than others is to improve the shift feel. A heavier shift **** will have a more "solid" feel when you put it into gear.
On the other hand, a light **** will have more of a "notchy" feel when you put it into gear.
It's really personal preference on this one. I like my light weight DC ****!!
My wife on the other hand really likes her Skunk2 because of the solid feel. With a heavier shift ****, the shift will feel more precise (sp?).
Anyways, I hope this helps!!
Old Nov 29, 2003 | 05:21 PM
Kendall's Avatar
I personally prefer the heavier one, I use an OEM ITR shift **** and it's great, when combined with a short-throw shifter it makes shifting clean, easy, crisp, and fast. I had a Momo **** that weighed considerably less that the ITR one and it felt like crap compared to the heavier one.
Old Dec 6, 2003 | 05:08 PM
Default Re: (dc231)
Would you guys get the heaviest one out of all, or just the regular heavy one?
Old Dec 6, 2003 | 09:28 PM
martini's Avatar
Default Re: (spacekid987)
I say go for the heaviest one.
but there is also the shape of the ****, and the looks of it to consider.
Old Dec 7, 2003 | 03:46 PM
iam7head's Avatar
Default Re: (JDMTyPeRHaTcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTyPeRHaTcH &raquo;</TD></TR><TR><TD CLASS="quote">i rather go with a heavier shift ****, better for fast shifting</TD></TR></TABLE>
that only what you think in your head, the weight of the **** have nothing to do with how fast you can shift, well, if it give you a better grip/feel, then i suppose I am wrong.
Old Dec 9, 2003 | 03:41 PM
JDCzar92Hatch's Avatar
I personally like the heavier one cause of the easier shifting which is why i have a heavier ****.
Old Dec 9, 2003 | 03:46 PM
Kendall's Avatar
Default Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">that only what you think in your head, the weight of the **** have nothing to do with how fast you can shift, well, if it give you a better grip/feel, then i suppose I am wrong.</TD></TR></TABLE>
I have to disagree with you. By using a heavier shift **** you have more momentum going into the next gear, but the force required to move either **** is still next to nothing for just about any human capable of driving a car. So what you end up with when you have a heavier **** is one that requires only as much force to move as a light one but goes into the next gear faster and crisper.
Old Dec 9, 2003 | 09:59 PM
iam7head's Avatar
Default Re: (dc231)
look at your shift assembly, look at the how the whole lever works, it aint gonna change anything unless you got a 12lbs **** swingin'
Old Dec 10, 2003 | 08:28 AM
EJ1 wilcox's Avatar
My wife has had the Skunk2 shift **** on her car for a few years and I when I switched her to a lighter DC shift **** she didn't like it because it felt "hard to shift" for her...
It definately feels more knotchy with a lighter shift **** and more positive with a heavier shift ****!
Even though Skunk2 isn't 12lbs or whatever it still really makes a difference you can feel...
Old Dec 10, 2003 | 09:34 AM
Red D Dragon's Avatar
I have to say that there is a noticeable difference with the skunk2 **** and stock **** which is much lighter. Even though you wouldn't think so but the heavier the smoother the lighter the more notchier it feels.
Old Dec 11, 2003 | 05:38 PM
neutron91's Avatar
Default Re: (koreanwilcox)
skunk2 gets a big from me... their **** is the best one i have owned... i could put my car in gear with a finger... i used to have a momo ****... it sucked gigantic elephant *****
Old Dec 11, 2003 | 07:42 PM
JLange's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">look at your shift assembly, look at the how the whole lever works, it aint gonna change anything unless you got a 12lbs **** swingin'</TD></TR></TABLE>
have you ever had a heavy shift ****? i went from a duracon plastic spoon ****, to a s2000 one, and shifting is so much easier and faster, requires less work to shift
Old Dec 11, 2003 | 08:12 PM
Lsos's Avatar
I think what it comes down to is that a heavier **** "numbs" the feel of the transmission. Kind of like a heavy flywheel absorbs engine vibrations better, a heavy shfter will absorb the feel of the transmission "better". I don't really think this is a good thing, but I can see how it would make it seem like the shifts are smoother: simply because the notchyness of a transmission is absorbed by the **** instead of your hand.
Carkid95
Jan 21, 2014 07:28 PM
Rydaddy
Oct 28, 2002 04:51 PM
Calavera
Feb 11, 2002 12:14 PM
