Shift Fork Wear
Old Oct 31, 2006 | 03:43 PM
neo_'s Avatar
Default Shift Fork Wear
Got a question for you guys. Its my first time with tranny work. Take a look at my shift fork and tell me if this is wear or if this is how they are cast. Because all of my shift are the same in the wear, and there is a little ridge if you look at the top view (last pic) that is right where the wear pattern is:
Is this normal wear?
Old Oct 31, 2006 | 03:53 PM
Bense's Avatar
Default Re: Shift Fork Wear (_eoN)
i need some pictures for reference, zoom out some.
and don't edit these pictures out, i may need them later
Old Oct 31, 2006 | 04:03 PM
neo_'s Avatar
Default Re: Shift Fork Wear (Bense)
Here you go:
Old Oct 31, 2006 | 04:04 PM
Black R's Avatar
25 Year Member
get the calipers out and measure at that groove. report back and i'll tell you if it's within spec.
Old Oct 31, 2006 | 04:11 PM
Willard's Avatar
That does not look 'too' bad... but check to see if it is with-in spec with Ken R0cker!
Old Oct 31, 2006 | 04:20 PM
RTW DC2R's Avatar
the part you want to try to measure is where the RED arrows are. Sometimes you will get a round arch wear mark with the BLUE arrows as well. as I stated before if you didnt have any problems shifting gears then you are probably fine(especially if the synchros arent worn too bad). if anything it might be a bit less crisp of a shift with worn forks.
Old Oct 31, 2006 | 04:29 PM
Bense's Avatar
lol, everyone's in here. what's up dudes
Old Oct 31, 2006 | 04:35 PM
neo_'s Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">lol, everyone's in here.</TD></TR></TABLE>
I invited them all
- Will have measurments tommorow, don't have calipers right now.
And oh, I did have some shifting issues (no reverse gear and nothcy 3rd). 5th/Reverse Syncro Sleeve is completly gone for sure.
Old Oct 31, 2006 | 04:52 PM
RTW DC2R's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">lol, everyone's in here. what's up dudes </TD></TR></TABLE>
this dude helped me out a lot on my first tranny rebuild.
if you cant hit reverse, thats definitely related to teh 5/rev synchro. mine were pretty chewed as well but not bad enoughh to worry about right now. my main issues were 3/4 syncho set and 4th gear (which I didnt even replace at this point because I dont really have any shifting problems other than an occasional rough 4th gear shift, so I DID replace 4th gear itself bc the dog teeth were pretty gnawed up), and the mainshaft clutch housing bearing. then some slight issues with the new CS/FD fitment which I STILL havent heard back on from the manufactuer
Old Oct 31, 2006 | 05:11 PM
neo_'s Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">
if you cant hit reverse, thats definitely related to teh 5/rev synchro. </TD></TR></TABLE>
My problem is the 5th/reverse syncro sleeve teeth, they're all chewed up and only let the gear inside the sleeve slide one way (5th) and not the other way into reverse. I'll have some pics tommorow of it for comic relief.
Also forgot to mention that a few bearings have some ridiculous play.
I chose to rebuild the tranny with:
New Bearings/Seals
Gear Speed Carbon Coated Syncros
JDM 4.7 FD
+ All the misc broken parts, so far:
5th Gear (some teeth are chipped)
Modified by _eoN at 9:23 PM 10/31/2006
Old Oct 31, 2006 | 05:16 PM
Bense's Avatar
Default Re: (_eoN)
If you want to get some more pics, get some pictures of this stuff.
so we can see the condition of the dog teeth and part of the synchros:
Inside of synchro sleeve:
inside of synchros
The more pictures you take and post, the more we can help you
Old Oct 31, 2006 | 05:25 PM
Bense's Avatar
Default Re: (Bense)
Old Oct 31, 2006 | 05:32 PM
neo_'s Avatar
Default Re: (Bense)
Here check out my syncro sleeve, it allows the gear that sits inside to only slide one way (5th) and not the other way (reverse) because of the chewed up teeth:
I know I need to replace the sleeve for sure, but the hub gear that sits inside it has some scaring in it. Should I replace that also?
Old Oct 31, 2006 | 05:46 PM
Bense's Avatar
can you get any shots where it shoes the ends of the teeth?
Old Oct 31, 2006 | 05:59 PM
neo_'s Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">can you get any shots where it shoes the ends of the teeth?</TD></TR></TABLE>
Old Oct 31, 2006 | 06:34 PM
Bense's Avatar
WOW, that's pretty bad lol.
how did they get that bad?
Old Oct 31, 2006 | 06:41 PM
neo_'s Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">WOW, that's pretty bad lol.
how did they get that bad?</TD></TR></TABLE>
Good question...
Helms recomends that if you need to replace the Sleeve that you also replace the hub gear. Any truth to this?
Old Oct 31, 2006 | 07:03 PM
Bense's Avatar
Default Re: (_eoN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _eoN &raquo;</TD></TR><TR><TD CLASS="quote">Helms recomends that if you need to replace the Sleeve that you also replace the hub gear. Any truth to this?</TD></TR></TABLE>
lol, I don't bother with that stuff. I check to make sure it fits and slide correctly and then slap it together.
if you order a sleeve kit, it will come with the hub though. you can't order JUST a sleeve.
Old Nov 1, 2006 | 04:53 AM
RTW DC2R's Avatar
Default Re: (Bense)
damn neo that 5/R looks beat lol you could try to dremmel the teeth some to reshape them and see if that helps if you dont want to buy the full 5/R set right now. I was going to do that with mine but decided not to since I was still able to shift without much problem prior to removing the trans.
if you order a sleeve kit, it will come with the hub though. you can't order JUST a sleeve FROM HONDA.</TD></TR></TABLE>
yup, which is such a ball breaker because it forces you to spend almost $200 lol. I only needed a 4th gear and the brass synchros for 3rd and 4th, the sleeve and hub are ok. Gearspeed will sell individual parts of the "sleeve set" I believe but they are on back order for most parts until atleast December. So I just replaced 4th gear with a B16 4th gear (cheaper than "Acura" 4th gear, same size/dimensions and ratios) and slapped it back together for now.
On another note, I noticed many of my bearings had play as well. Through researching it appears most ppl say the same thing and that its actually normal for the bearing races to have a lot of play. Especially the large mainshaft bearing on top. I can confirm this as I decided to replace that bearing anyway and the new one had just as much play. The good thing about that is that you can look inside the race and check for irregular wear. The two bearings at the top of the countershaft also have a bit of play. I highly suggest cleaning the **** out of those bearings with parts cleaner, and then put some clean fluid on them, and spin them. If they arent smooth or feel lumpy/notchy/gritty, get rid of them. The needle bearings are hardest to inspect and test because they have so much play and are loud as fawk.
Old Nov 1, 2006 | 08:06 AM
Gearspeed-Performance's Avatar
The fork is actually in pretty good condition from the angle of the picture. Bad forks will have very deep grooves on the ends. The sleeve is REALLY bad. Swap it out with an OEM sleeve set(comes with center hub, sleeve and corresponding synchros) and make sure the 5th gear is good and you are set. Check the bearings as RTW DC2R stated as well. If you have the cash...opt to change the bearings just to be on the safe side if the mileage is up there. Good Luck!
Old Nov 1, 2006 | 10:21 AM
IN VTEC's Avatar
Default Re: (_eoN)
Man, that sleeve is toast. I've seen shift forks much worse than that.
Mic the shift fork where it contacts the sleeve to push it up or down at the thinnest portion. The service manual should have a minimum spec for the thickness of the shift fork for that area.
Old Nov 1, 2006 | 02:34 PM
neo_'s Avatar
Default Re: (IN VTEC)
Shift Fork is good, here is a refrence pic:
Old Nov 1, 2006 | 02:38 PM
Bense's Avatar
I wish all transmission threads were this simple.
90% of them if one were to say "mic the fork"
OP would be like "durrrrr mic????"
Old Nov 1, 2006 | 04:20 PM
FaceTuned's Avatar
Default Re: (_eoN)
damn my syncro sleeve looks just like that i need to replace the hub/sleeve and 5th gear im in the process of trying to hunt down a good 5th gear/hub and sleeve.
Old Nov 1, 2006 | 04:22 PM
Bense's Avatar
B or D?
