sheared a bolt
Old Jul 4, 2001 | 02:40 PM
eviladam's Avatar
Default sheared a bolt
i just sheared the bolt at the bottom of my rear shock, anybody have suggestions? should i hacksaw the shock mount and buy a new bolt?
Old Jul 4, 2001 | 02:43 PM
Mr. Choi's Avatar
New User
Default Re: sheared a bolt (eviladam)
sheared a bolt????? what the hell does that mean, maybe stripped? if that is the, im not sure what to tell you since i dont no where its located and also cause i dont have the car you have. more infos please.
Old Jul 5, 2001 | 04:56 AM
D's Avatar
D
is the rear shock removed from the mount?
hrm... can you drill the rest of the bolt out? definatly going to be a pain in the ***.
good luck.
D
Old Jul 5, 2001 | 05:51 AM
miketegra's Avatar
Default Re: sheared a bolt (D)
Is it possible that the nut is welded on and you need to remove only the bolt? I remember back when I was dong the shocks on my old 86 Integra. I broke a socket trying to remove a suspension nut, and it turns out that the nut was welded on, and it was the bolt itself that needed to be loosened - just a thought.
Old Jul 5, 2001 | 06:16 AM
eviladam's Avatar
it's the self-locking bolt that attaches the shock to the lower arm. the head of the bolt broke off flush with the shock. this is on a 93 cx btw.
Old Jul 5, 2001 | 07:56 AM
DragII's Avatar
25 Year Member
I guess drilling it is about your only option, or hacksawing
Old Jul 5, 2001 | 12:33 PM
miketegra's Avatar
Default Re: sheared a bolt (DragIIcivic)
I can think of 3 options:
1. Use an extractor and hope it is stronger than the bolt head.
2. Drill the sucker out. There is a good chance you will mess up the threads, so you will need to tap new ones. You may be able to use a heli-coil, or similar to keep the hole size the same. If you don't have the tools, or the time and money to get the tools and learn how to tap threads, you may want to have a machine shop perform the work for you.
3. Shoot many rounds of 000 buck shot at it until you feel better.
Good luck amigo...
Old Jul 5, 2001 | 12:44 PM
G's Avatar
G
Cut the welded nut off as close as you can to the shock mount with your hacksaw or a grinder. Then get the same grade bolt with an external nut and use that until you feel like buying new shocks. Did the bolt head shear from loosening or tightening. If it sheared from tightening, you may be able to extract it......
Old Jul 5, 2001 | 01:26 PM
Steppin Razor's Avatar
New User
Default Re: sheared a bolt (G)
I also suggest trying a screw extractor.
OneDirection
Suspension & Brakes
13
Jan 17, 2005 07:19 AM
jweezy225
Nov 1, 2004 02:38 AM
CoolKat
42
Jul 17, 2003 08:36 AM
logictron2000
15
Apr 24, 2003 08:59 AM
Batoutahell
Oct 15, 2002 04:33 AM
