to shave or not to shave the flywheel?
Old Jan 5, 2003 | 09:19 PM
mycro_machine's Avatar
Default to shave or not to shave the flywheel?
just a lil quick ? is it best to shave off couple lbs off the flywheel or should i get a new lighten one? and this is for a h22a.
Old Jan 5, 2003 | 09:52 PM
airborne84000's Avatar
Default Re: to shave or not to shave the flywheel? (mycro_machine)
i wouldn't shave it at all unless you want to take the chances of it exploding and possibly killing you!!!
Old Jan 5, 2003 | 09:54 PM
10K2HVN's Avatar
Default Re: to shave or not to shave the flywheel? (airborne84000)
People gotta die someday...
Old Jan 5, 2003 | 09:57 PM
MGD's Avatar
MGD
Such a stupid comment.......i've shaved many flywheels, and never had a problem.
Keep in mind your not going to shave off 15 pounds, i'd say no more than 5 pounds
Old Jan 5, 2003 | 10:04 PM
Shawn C's Avatar
In The Garage
Default Re: to shave or not to shave the flywheel? (spoontang)
that wasnt a stupid comment. and personally, i would recommend just resurfacing it. im not a fan of light flywheels, but a fan of rotational inertia. i dont like my car to nearly die every time i push in the clutch. and for the haters, ive had plenty of flywheels- from ultra-light to lightened to stock. id rather have the strength and inertia of a factory resurfaced flywheel anyday.
Old Jan 5, 2003 | 10:29 PM
sgT's Avatar
sgT
Default Re: to shave or not to shave the flywheel? (22lbGS-R)
lighter is better, but the problem with the h22a flywheel is that the timing marks
are part of the flywheel which make lightening it a little bit difficult.
You can get aluminum ones but they lack the timing marks last time i checked.
maybe its worth a look though. as far as lightening the stock one, i wouldnt.
Old Jan 6, 2003 | 09:12 PM
10K2HVN's Avatar
is the ITR flywheel just an B-serise flywheel (18lbs) lightend at the factory (to 15lbs)??? because i want to lighten an ITR to 12lbs...
ajmj
Feb 9, 2005 11:59 AM
lilman36
Nov 20, 2003 12:00 PM
97F22B2
Sep 23, 2003 12:25 AM
Mr. 1582
17
Sep 21, 2003 06:21 PM
integranator
Jul 25, 2002 05:25 PM
