Setting Adjustable Timing Gear Degrees on a d16z6
Old Mar 11, 2004 | 08:24 AM
hman94's Avatar
Default Need Help Setting Adjustable Timing Gear Degrees on a d16z6
I need Help on What degree to set my adjustable Cam Gear on for optimum performance.
Modified by hman94 at 6:52 PM 3/11/2004
Old Mar 11, 2004 | 10:47 AM
SOHC_MShue's Avatar
Default Re: Need Help Setting Adjustable Timing Gear Degrees on a d16z6 (hman94)
you don't need to adjust it at all unless you have aftermarket cam. All its going to do is shift you power curve up or down. I would just keep it at 0.
Old Mar 11, 2004 | 01:38 PM
doublejz's Avatar
Default Re: Need Help Setting Adjustable Timing Gear Degrees on a d16z6 (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">you don't need to adjust it at all unless you have aftermarket cam. All its going to do is shift you power curve up or down. I would just keep it at 0.</TD></TR></TABLE>
Old Mar 11, 2004 | 01:59 PM
Rtype16's Avatar
Default Re: Need Help Setting Adjustable Timing Gear Degrees on a d16z6 (doublejz)
You see there is no settings for an adjustable cam gear. You have to set it on the dyno for where you want the power. After all if someone knew where to set it it wouldn't be adjustable.
sk8shorty012
Mar 13, 2006 11:26 AM
yellowturbo
Mar 24, 2005 12:42 PM
sk8rmike
Feb 23, 2004 02:56 PM
Ignitecivic
Nov 6, 2003 08:32 PM
Ignitecivic
Mar 17, 2002 12:28 AM
