Sensor Problem....need help?
Old Jun 16, 2003 | 08:11 AM
turboxsi's Avatar
Default Sensor Problem....need help?
my b16 bogs out only at WOT, the only thing i've found is the TP sensor is reading voltage backwards 4.5v (closed throttle) - .5v (WOT)...does anyone know what the problem might be?? or do i just need a new sensor?? I've some searchs and haven't found much on this.
Old Jun 16, 2003 | 09:24 AM
machine4321's Avatar
is it pluged in the corect way ...if not its got to be wired backwards.....cause its in spec
just backwards
what car
Old Jun 16, 2003 | 10:10 AM
turboxsi's Avatar
Default Re: (machine4321)
It is wired correctly i have checked with the helms manual but its reading the throttle specs backwards even though its wired right.
Plus if i reverse the power and ground to the sensor it doesn't bog out at WOT, but bogs out around 1500 rpms but you can rev through the bog.
could it just be a bad sensor???
Old Jun 16, 2003 | 12:21 PM
Dgr8wun's Avatar
Default Re: Sensor Problem....need help? (turboxsi)
if its not the sensor then maybe you fuel pump is having a hard time feeding the extra gas at WOT
Old Jun 16, 2003 | 12:52 PM
Kamin's Avatar
Default Re: Sensor Problem....need help? (Dgr8wun)
if you can get a free tps sensor to try it, definatley do
the TPS does control the fuel comming into the engine, so it would bog if its in a situation like yours.
Old Jun 16, 2003 | 01:03 PM
Perfectionist's Avatar
The only way a TPS can read backwards is if it's wired wrong or you are measuring wrong. It's got a supply voltage, a ground, and a 'wiper' in between. The 'wiper' is what moves with the throttle. Based on your description, the TPS itself would seem to be OK.
Old Jun 16, 2003 | 08:13 PM
turboxsi's Avatar
Default Re: Sensor Problem....need help? (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">The only way a TPS can read backwards is if it's wired wrong or you are measuring wrong. It's got a supply voltage, a ground, and a 'wiper' in between. The 'wiper' is what moves with the throttle. Based on your description, the TPS itself would seem to be OK. </TD></TR></TABLE>
Read the third reply in this thead and tell me what you think. Its mine and it had to do with what you said.
Tjabo
May 15, 2011 01:29 PM
airikkCRX
May 15, 2010 06:47 PM
airikkCRX
Apr 25, 2010 11:23 AM
deucedeuceEK
Apr 27, 2007 02:39 PM
EFRue57
Sep 17, 2005 05:41 PM
