Secondary rev limiter? Timing issue?
Old Mar 25, 2005 | 08:43 AM
BigDisarray's Avatar
Night Elf Mohawk
Default Secondary rev limiter? Timing issue?
Problem solved, thank you..!
Modified by BigDisarray at 1:09 PM 3/26/2005
Old Mar 25, 2005 | 08:45 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Secondary rev limiter? Timing issue? (BigDisarray)
Sounds like a vac. leak or your TPS is wack. You throwing a CEL?
Old Mar 25, 2005 | 08:47 AM
Night Elf Mohawk
Default Re: Secondary rev limiter? Timing issue? (Blaze45)
Yes, the CEL is on.
Old Mar 25, 2005 | 07:52 PM
PrettyLude's Avatar
jump the code, or bring it to autozone and ask them to do it
Old Mar 25, 2005 | 08:51 PM
Night Elf Mohawk
Default Re: (PrettyLude)
The code is idle air control valve, or something of that nature. Anyway, we took a look at it, and someone had tried to remove it before, but broke the bolts off. So, we have to take off the throttle body to get to it .
Thanks to anyone who helped.
Old Mar 25, 2005 | 10:46 PM
PupaScoopa's Avatar
Default Re: (BigDisarray)
Fix the mechanical issues before you try to tune it...
Danny Rogers
Mar 31, 2019 02:35 PM
mokume
Engine Management and Tuning
Aug 29, 2011 07:36 AM
dragon_lowrider
Dec 11, 2010 11:11 AM
EJ2-Fluffy
Aug 30, 2005 03:45 PM
spyderracing
Sep 30, 2004 05:59 PM
