searched and found nothing...PLEASE HELP
Old Feb 3, 2003 | 10:21 AM
2000CX's Avatar
Default stalling for no APPARENT reason...
need some help on this one...FAST! short and sweet...after car warms up, everytime i come to a stop...it stalls. funny thing is it starts right back up. all i have is an AEM short ram and axle back. i have checked for vacuum leaks and found nothing. tried resetting ECU and nothing changed. i am about to go to honda for help but i have to take everything off for them to even look at it. any ideas? by the way, i have a 2000 CX H/B
[Modified by 2000CX, 8:31 PM 2/3/2003]
Old Feb 3, 2003 | 10:44 AM
Tweakmeister's Avatar
Default Re: searched and found nothing...PLEASE HELP (2000CX)
check your throttle body, cables, etc. first.
Old Feb 3, 2003 | 11:18 AM
2000CX's Avatar
Default Re: searched and found nothing...PLEASE HELP (Tweakmeister)
what should i be looking at on the TB? if the throttle cable were loose, is this something that would not start acting up until the car was warm? is tightening it ok? i have heard they can snap...is that true?
Old Feb 3, 2003 | 12:04 PM
2000CX's Avatar
alright...tried tightening the throttle cable. WHAOOOOOOO...way too much the first time!!! took it back a little and it idled ok at stops...still think it might be something else though...anymore ideas? what to look at on the TB?
[Modified by 2000CX, 4:04 PM 2/3/2003]
Old Feb 3, 2003 | 02:30 PM
kyle h.'s Avatar
vacuum leak, check again.
[Modified by kyle h., 11:30 PM 2/3/2003]
Old Feb 3, 2003 | 02:32 PM
steve_s's Avatar
Default Re: searched and found nothing...PLEASE HELP (kyle h.)
Your putting the clutch in once you come to a stop right???
Old Feb 3, 2003 | 03:14 PM
qcoffey's Avatar
What does your car idle at when warm? I had a customer that had the same problem on a '00 EX. He only had i/h/e and there wasn't anything wrong with the install of the parts(they were done by him so we checked just in case).
I would look at your plug wires, cap and rotor. We changed these on this customers car and we never had a problem.
Old Feb 3, 2003 | 03:28 PM
fire7882's Avatar
Default Re: searched and found nothing...PLEASE HELP (qcoffey)
idle might be to low
Old Feb 3, 2003 | 04:27 PM
2000CX's Avatar
Default Re: searched and found nothing...PLEASE HELP (fire7882)
i tried spraying water and carb cleaner EVERYWHERE in the bay...i really don't think its a vacuum problem. when i was driving around before my last post i noticed an odd idle...but no stall. qcoffey, i wish i knew what i was idling at...i have NO tach so you feel a tune up might cure the problem? i would be willing to try. i was just talking to a guy at the local speed shop and he said PGM-FI possibly?!?! who knows.
Old Feb 3, 2003 | 04:40 PM
qcoffey's Avatar
How many miles are on your car? I say always start with the basics. These would be cap, rotor, plugs and plug wires. You might have something simple like a cracked distributor cap. I've seen cars that won't start because of something simple like this.
Also, do you have a multimeter? If you don't have a tach but a good multimeter(electrical tester) then you can switch to RPM mode and watch your readings. Good Luck.
Old Feb 3, 2003 | 04:44 PM
2000CX's Avatar
just over 35k on the motor now...i hear that is low for a tune up right? i wish i had various cool tools like a multimeter...no luck though. i should go with all stock replacements right? cap, rotor, and plugs? do you have any feeling on the PMG-FI scenario?
Old Feb 3, 2003 | 05:09 PM
qcoffey's Avatar
I highly doubt the problem has anything to do with your fuel injection. If you replace the parts I listed you want to go with Honda OE. With the plug wires you can get a good set from another manufacturer, i.e. MSD or NGK.
Old Feb 3, 2003 | 05:14 PM
2000CX's Avatar
thanks a lot for all of your help man...i will be getting on that asap. i might get back to you if i have anymore questions. one more for you...average cost for all these parts...not the wires though...i know the performance ones are mad expensive. heres to you
c r x_s i
26
Apr 6, 2007 09:47 PM
_SHEP_
Jul 29, 2005 10:26 AM
josh200536
Jun 27, 2005 07:10 PM
blackc
Sep 22, 2003 05:04 PM
R0476
Jul 17, 2001 12:14 PM
