Seam welding
Old Feb 2, 2003 | 04:40 PM
Spilner's Avatar
Default Seam welding
I am welder TIG/MIG/ARC by trade and was wondering if anyone had any knowledge of wer the best places on a 92-95 Civic HB were the best to seam weld to offer better solidarity to the frame, chassis etc.? I want to get the car all butoned up before she goes into the paint booth.
Old Feb 2, 2003 | 07:06 PM
integra6650's Avatar
Default Re: Seam welding (Spilner)
never heard of anyone doing this before but if your just looking for away to use your abilities i would want a roll cage in mine or maybe one day a tube chassis hehe o the possibilities from what i know the whole frame system is pretty tight but could be wrong
Old Feb 3, 2003 | 05:45 AM
evolve's Avatar
You basically weld all the seams you see, and the welds should be 3 to 4 inches apart. Spreading the welds will prevent chassis warpage-from the welding. Use common sense, such don't waste time on wheel wells-best to put on a reinforce layer. Never done, but I here it does wonders for the structure.
Old Feb 3, 2003 | 06:35 AM
Raz1983's Avatar
if im not mistaken, seam welding uses a seam welder, where they press weld? it.
and again if im not mistaken, dont you have to drill through the first layer?
3 inches seems alittle too far away.... ive heard something like 3-5cm
Old Feb 3, 2003 | 07:04 AM
evolve's Avatar
Default Re: Seam welding (Raz1983)
I'm not sure about the welder. Drilling would probably be a good idea, but I never read that it was necessary. 3-5cm is the proper for racing applications and experienced frame welders. I gave a larger margin of error. Warpage should be number consideration over rigidity. Though, either spacing will give a stronger frame one will be harder for the inexperienced in this situation. But like he said drilling will also help with the warpage issue.
Old Feb 3, 2003 | 10:48 AM
rotten's Avatar
Make sure the sanctioning body you're going to run for allows seam welding in your class--there are some that don't.
As to where you seem weld, I've been told you want to reinforce the strut towers and in between the strut towers.
-k
Integra4lyfe069
Apr 21, 2008 05:13 PM
Civicman86
Paint and Body
31
Nov 30, 2007 12:43 PM
b16hatchsi
Aug 16, 2007 06:44 AM
See Are X
Nov 30, 2002 03:25 PM
thinkbrianthink bu
Nov 7, 2002 11:32 AM
