Sand down rod and main bearings ok..........?!?
Old Mar 13, 2007 | 05:53 PM
Dat1BVtecN's Avatar
Default Sand down rod and main bearings ok..........?!?
Is it ok to sand down some main and rod bearings?!? there are VERY VERY LITTLE scratches on em and i took them to a machine shop and they said its ok because it wasnt anythin major, just use 1000 grit sandpaper i believe thats what he said, anyone done this before of what yall think?
Old Mar 13, 2007 | 05:54 PM
99B16Si's Avatar
i would never touch a bearing with sand paper
Old Mar 13, 2007 | 06:07 PM
Dat1BVtecN's Avatar
Default Re: (99B16Si)
hmmm, ok ok, anyone else?!?
Old Mar 13, 2007 | 06:28 PM
NJIN BUILDR's Avatar
Default Re: (Dat1BVtecN)
The scratches are better than anything you can do to them with sandpaper.Just leave the scratches.Use them as is or replace them.
Old Mar 13, 2007 | 06:33 PM
Dat1BVtecN's Avatar
Default Re: (NJIN BUILDR)
ok ok, anymore inputs!??
Old Mar 14, 2007 | 06:38 AM
Dat1BVtecN's Avatar
bump
Old Mar 14, 2007 | 08:05 AM
Dat1BVtecN's Avatar
bump1
Old Mar 14, 2007 | 08:29 AM
EE_Chris's Avatar
Sandpaper + bearings = bad idea.
Old Mar 14, 2007 | 09:33 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
your 'machine shop' sucks. never ever, ever, ever, ever, ever go back there for ANYTHING!
Old Mar 14, 2007 | 10:03 AM
Dat1BVtecN's Avatar
Default Re: (full Circling)
i took them to a machine shop, not my machine shop! but yea thanks for the input.
Old Mar 14, 2007 | 03:36 PM
dbiker207's Avatar
all the sandpaper is gonna do is embedd sand particals into the bearing, this may scratch the crank. dont ever touch it with sandpaper, get new bearings for the little that they cost.
Old Mar 14, 2007 | 04:08 PM
non-VTEC's Avatar
BUY NEW FREAKING BEARINGS!
dont screw around with them.....and never go back to that machine shop!
Old Mar 14, 2007 | 04:30 PM
Dat1BVtecN's Avatar
Default Re: (non-VTEC)
i kno!!! i get the point now!!!
Old Mar 15, 2007 | 04:36 AM
Mikey3000's Avatar
dont go back to that machine shop ever!
Old Mar 15, 2007 | 03:19 PM
arc_55's Avatar
the markings on the bearings are there for a reason... non oil pressure starts, power thrust and other causes. If you sanded the bearings you woulcd be changing clearances and it would be rough on your crank.
Rasmusm
Jun 17, 2013 10:37 AM
TB123
Jun 24, 2011 01:46 PM
Geno
Oct 27, 2004 07:22 PM
turbociv
Mar 11, 2004 06:44 PM
