same brand of piston....different cr....different tolerances/clearances?
Old Dec 2, 2003 | 06:33 PM
GOLDBERG's Avatar
Default same brand of piston....different cr....different tolerances/clearances?
is this true??9.1 compared to 11.8cr pistons..same brand, same bore why would the tolerances/clearances be tighter on the high cr pistons?can someone explain??or is it just some marketing ploy to get me to buy the oversize pistons they have in stock(which aint gonna happen but maybe they figure it will)
Old Dec 2, 2003 | 06:36 PM
MackSpeed-616's Avatar
Default Re: same brand of piston....different cr....different tolerances/clearances? (GOLDBERG)
1) they are likely made from different alloys.
2) f/i and n/a pistons will require different clearances
Kendall's Avatar
The clearances may be tighter to reduce the amount of air that slips past the piston to the top piston ring, which means more air in a smaller area, which means more compression.
Old Dec 2, 2003 | 07:50 PM
keithg's Avatar
Cast pistons are run with tighter tolerances than forged pistons. It has something to do with different expansion rates of cast versus forged. I have never heard of compressoin being a factor in tolerances.
Old Dec 2, 2003 | 09:57 PM
mmuller's Avatar
Mad Scientist
Default Re: same brand of piston....different cr....different tolerances/clearances? (keithg)
also, FI pistons run looser tolerances, because they are expected to run hotter, thus expanding more
Old Dec 2, 2003 | 10:03 PM
hybridEj6's Avatar
Default Re: same brand of piston....different cr....different tolerances/clearances? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">also, FI pistons run looser tolerances, because they are expected to run hotter, thus expanding more</TD></TR></TABLE>
exactly
Old Dec 3, 2003 | 03:08 AM
GOLDBERG's Avatar
Default Re: same brand of piston....different cr....different tolerances/clearances? (ekhybrd)
would the loosness be detrimental in a n/a setup?
here are the spec from jeff
0033 for turbo and .0028 for all motor.
.0033 is within tolerance for all motor, its just a little loose.
.0035 is the limit for all motor.
.004 is the limit for turbo.
whatchall think?
Old Dec 3, 2003 | 04:30 AM
meanEG's Avatar
you took my words. this is why they have different piston to wall cleara nce's
.adam.
Nov 21, 2007 02:39 PM
huge230
Oct 16, 2007 05:09 AM
UK Accord
Aug 21, 2007 12:29 PM
prostreetonline
Jul 20, 2004 11:21 AM
b20ek
Apr 18, 2003 02:37 PM
