running without TPS
Old Feb 11, 2004 | 08:47 PM
htownteg's Avatar
Default running without TPS
my car was idling really bad when warmed up...so i unplugged the TPS plug and now it idles great...anyone think running without TPS is bad?
Old Feb 11, 2004 | 09:00 PM
Kataku2K3's Avatar
Default Re: running without TPS (htownteg)
I've seen weird stuff happen with the TPS just as you have... Most cars don't run well at all when there's no TPS reference (in fact they all shouldn't) but I have seen a seen a few cars that somehow run without it... A long while back my friend's EH2 with a Z6 motor starting having an irratic idle (up down up down up down) but if he pulled the TPS for a few seconds and then put it back on, it would idle perfect... After it became a pain in the *** to pull the TPS connector every time he started his car he just left it off... It still managaed to run just fine, nothing like what you would expect... In fact it ran just as any normal car would... Bottom line is an ECU needs a TPS reference so it really is needed... To this day I still don't know how his car ran fine...
Old Feb 11, 2004 | 09:10 PM
htownteg's Avatar
Default Re: running without TPS (Kataku2K3)
his car sounds alot like mine...i've done what he used to do by pulling the TPS and he started the car and then putting it back in...thats just the same as pulling it an leaving it..the ecu isnt going to recognize it anyways until you turn off the car and turn it back on...but yea i don't know how my car is running without it...i thought the ecu needs it to know where the throttle is at so it can idle...
Old Feb 11, 2004 | 09:12 PM
htownteg's Avatar
i have another TPS that i'm going to try just to see if my current TPS is bad...i took off my current TPS to see if the spring was broken but it was fine..maybe it's something electrical inside the TPS
Old Feb 13, 2004 | 04:38 AM
htownteg's Avatar
Old Feb 13, 2004 | 10:21 AM
rsbad454's Avatar
Default Re: (htownteg)
my 88 dx has a code 7 for the TPS.......if the check engine light is off the engine will idle kinda weird and jerk while driving. If the check engine light is on it will run fine. Im not putting any money into it cause i have a B16 waiting to drop in. Just thought id share my TPS experience.
Old Feb 13, 2004 | 02:46 PM
PHiZ's Avatar
Default Re: (rsbad454)
Well, disconnecting the TPS probably puts it in open-loop mode, so it is just running off maps...
What ya think?
-PHiZ
Old Feb 13, 2004 | 07:52 PM
Sliced Beard's Avatar
Default Re: (PHiZ)
hmmmm this brings ideas to mind
if it causes your car to run off of maps, then wouldn't it run better fi you had a tuned ecu such as hondata or ems because then it would run off of tuned maps fi it was dyno tuned or wide band tuned. it might not be all that good for stock ecu's but with a tuning system wouldn't it be better????
Old Feb 14, 2004 | 06:18 AM
mmuller's Avatar
Mad Scientist
Default Re: (dirtyd463)
hondata and such still use closed loop, they have different maps, but they still use input from sensors to adjust timing/fuel BASED on the maps.
Running open loop mode will affect drivability and gas mileage
Old Feb 14, 2004 | 07:28 AM
PHiZ's Avatar
Default Re: (mmuller)
I know in hondata you have the option to enable/disable closed-loop altogehter.
-PHiZ
Jhicks
Jan 25, 2012 07:06 AM
Throwback23
May 4, 2010 09:33 PM
spintboy
Jan 31, 2008 08:06 PM
drycreekgsr
Sep 4, 2006 06:50 AM
SpoolnG2
Jan 1, 2003 08:32 AM
