Running peak & hold injectors without resistor box?
Old Apr 29, 2006 | 11:53 AM
User 5426's Avatar
Default Running peak & hold injectors without resistor box?
I have a eh2 swapped with an OBD1 h22a on a P13 ecu. I can't test to see what kind of injectors that I have ATM but I will check as soon as I get my car back. I bought the car swapped already and had to correct many things that wern't done right. Yesterday a friend that I took my car to noticed that the box was missing.
The thing is that I've been running this car for around 3 years with this setup and had no problem yet. The car is running a little rich so I don't know if that have anything to do with it.
I'll test the injectors to see if they are peak and hold or saturated. If the injectors are peak a hold, how would someone explain the injectors and ecu lasting for this long?
Old May 5, 2006 | 08:06 AM
devnull's Avatar
Car wouldn't run with Peak & hold. He is probably using stock injectors. Not a bad thing since all Honda Injectors are all 240cc rated.
Old May 5, 2006 | 05:43 PM
User 5426's Avatar
Default Re: (devnull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devnull &raquo;</TD></TR><TR><TD CLASS="quote">Car wouldn't run with Peak & hold. He is probably using stock injectors. Not a bad thing since all Honda Injectors are all 240cc rated.</TD></TR></TABLE>
Wrong, I have 345cc rated Peak and Hold injectors and they are stock. I had the resistor box installed. The car runs the same. I was just very lucky that nothing failed due to the missing box.
I am not trying to be a dick by telling you that miss-information is far worse than no info at all. I know that you are trying to help as we all are.
Thanks for the reply.
Modified by EsQueue at 6:54 PM 5/5/2006
GT500FTW
Nov 29, 2012 03:10 PM
columbushatch
Jan 17, 2009 11:08 AM
EKHWhat
Feb 2, 2007 05:38 PM
ATS*Mark
Sep 26, 2003 03:23 PM
hybridreams
Sep 12, 2003 09:22 PM
