rough shifts because of axle??
Old Sep 11, 2003 | 01:21 AM
fu*kfaceC1EH2's Avatar
Default rough shifts because of axle??
ok here it is. the new axle from the swap had a ripped boot. last night i swapped out the axle with a new one. I had to use a C clamp around the old axle, right where it meets the half shaft for leverage. I pryed and it came out. I first tried everything. I used a flathead and tried prying it out of the half shaft at first, but didn't budge. And so i got the new one in, and now today, I took it out, and now all the sudden the gears aren't smoothly shifting. 5th almost grings everytime. And first doesn't go in easy at all.
I was wondering if it was possible that I pryed against the half shaft in some wierd way making it possible for gear oil to leak out of where the shaft goes into the tranny? Causing the rough shifts? I didn't touch the shaft going into the tranny at all, just the other side where it meets the axle. ALSO, I was told that when i put in the new axle, is it supposed to 'click' into place by that little c ring on it.? I didn't hear it snap into place, should I have heard something lock into place? ALSO (#2) WHere the axle goes into the half shaft, the end of the axle, that little lip on the axle, didn't go all the way up into the half shaft, is that normal?
LASTLY, My clutch master cylander was slowly leaking and i haven't replaced that yet. Because also along with the bad shifts, the clutch is now engaging when i barely release the pedal some of the time since today, where normally it engages when my foot comes out more. Maybe it's just that being bad and messing up the clutch in turn messing up the shifts? Sorry about the longness of this damn thing, but I know you guys dont' mind too much and always help me out. Thanks for any intelligent input or ideas!
-Danny
( i put this in hybrid too, can't make up my mind)
Old Sep 11, 2003 | 01:22 AM
Default Re: rough shifts because of axle?? (fu*kface95hatch)
sorry about the poll thing, i don't know why that's on there or how i f'ed that up. Ignore it thanks.
b20acura
Feb 25, 2007 10:47 AM
Hoppa
Dec 5, 2006 08:51 AM
vha27
Nov 17, 2003 07:27 PM
fu*kfaceC1EH2
Sep 12, 2003 09:13 AM
fu*kfaceC1EH2
Sep 11, 2003 10:06 PM
