rough idle question
Old Feb 13, 2008 | 01:02 PM
tallyturbo's Avatar
Default rough idle question
ok my 97 ek hatch 1.6
once the car warms up the idle goes up and down up and down if i tap the gas it stops sometimes. the only code i have is primary o2 but the car runs great other than the idle issue. if i unplug the map it stops if i unplug the tps it stops but idles up ive checked for vacume leaks and i found none. any help would be great
Old Feb 13, 2008 | 01:10 PM
tnez's Avatar
Default Re: rough idle question (tallyturbo)
IACV?... maybe you need to clean/replace it...
Old Feb 13, 2008 | 01:14 PM
tallyturbo's Avatar
Default Re: rough idle question (tnez)
i did clean it is was pretty dirty but it cleaned up nicely
Old Feb 13, 2008 | 01:17 PM
tallyturbo's Avatar
not to mention it isnt giving me any codes is that possible?
Old Feb 15, 2008 | 04:38 PM
tnez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo &raquo;</TD></TR><TR><TD CLASS="quote">not to mention it isnt giving me any codes is that possible?</TD></TR></TABLE>
maybe.. the only car we had this happen to is an 87 civic si...
TB gasket, IACV, FITV, fuel management... thats some of the **** I would check. if worst comes to worst... bust out the tools and start an air intake rebuild
this is confusing me...
Old Feb 16, 2008 | 01:45 AM
slowcivic2k's Avatar
You probably have a vacuum leak somewhere. Unplug the IACV, this should make the leak much more audible. If your idle is over 450rpm without the IACV, you more than likely have a leak. Gradually pinch off the PCV hose with a pliers and towel to decrease the idle further, until you have isolated the leak.
Old Feb 16, 2008 | 08:26 AM
vlang29's Avatar
Default Re: rough idle question (slowcivic2k)
https://honda-tech.com/zerothread?id=1979500
good info
alghafat424
Nov 13, 2006 01:29 AM
meagainsttheworld
Sep 10, 2006 09:30 PM
hondachris1994
23
Mar 11, 2006 08:47 AM
guywitaDA
Dec 29, 2005 11:05 AM
turbochic
Jun 17, 2003 11:12 AM
