Rough feeling Idle and engine mounts
I reciently swaped in a new engine in my 94 integra, while taking out my old b18b the front drivers engine mount basicaly fell apart. I cut off the rubber and put an old shock bumpstop on it (getto)
I plan on getting a new mount but I'm wondering if this is why the car shakes a bit @ idle and idles a bit rough.
EDIT: is this a honda part number too????
[Modified by legendboy, 8:57 AM 8/9/2002]
I plan on getting a new mount but I'm wondering if this is why the car shakes a bit @ idle and idles a bit rough.EDIT: is this a honda part number too????
I don't know exactly what you you did to the mount, but does it shake if you look at it while the car is running? I'm sure this is part of your problem, but also check your timing if you havent already.
Thanks, J
Thanks, J
bearboy80
Jul 9, 2003 01:49 PM
