Ross Piston Question!!
Old Jun 15, 2003 | 07:48 PM
TurboTeG4's Avatar
Default Ross Piston Question!!
Well ive decided to go with ross pistons is this a wise choice??Cause it comes with rings and everything included. Im goin to be running a b18c1 with drag gen 3 turbo, can u tell me the compression and which would be better for me to get in the chart???
http://cgi.ebay.com/ebaymotors...72254
Is that a good deal how much overbore is it .20???
Old Jun 15, 2003 | 07:57 PM
poison's Avatar
Default Re: Ross Piston Question!! (turbocivic4)
The compression ratio you get mainly depends on the dish, stroke, domed, bored in, or flat, as well as rod length and stroke as well on the bottom end.
You will need to get the specs of the rods, and all the specs of the pistons, to determine the CR.
But for compression, and drag gen 3 turbo set up, I would be in the 8.5:1 ball park area. With a built bottom end, you could run about 25 PSI provided it is tuned and race fuel.
As for being .20 overbore. Usually when you have a block sleeved, and re-honed, there is usually .20" shaved off inside the cylinders, making the piston more fit.
HTH.
Old Jun 16, 2003 | 12:43 AM
TurboTeG4's Avatar
Default Re: Ross Piston Question!! (poison)
can i use the stock sleeves for 3.209 bore?
seigisama
Engine Machining & Assembly
Aug 5, 2016 03:47 AM
aschrock
Mar 17, 2012 09:51 PM
fjt
Jun 9, 2010 06:18 AM
regamaster
12
Mar 18, 2004 04:59 PM
greengangsta
Mar 18, 2002 07:23 PM
