rod bearings and mains
Old Jul 28, 2004 | 08:59 AM
svmnredracr's Avatar
Default rod bearings and mains
So say I just got your block sleeved, and palnning on going turbo, I purchased some after market pistons and rods. My question is .... When you get the rods are they within OEM specs that I could just use the same color bearings or not? And what if I go with ACL bearings?
Old Jul 28, 2004 | 12:13 PM
thad
Guest
Posts: n/a
Default Re: rod bearings and mains (svmnredracr)
if you go with ACL they are all gonna be the same size (green) but if you wnat oem (i would) you need to know what size the rod bores are, eagles for gsr/h22 are #3, then you go by the number on the crank and selct the color of bearing you need. it's best to find out what # the bore is for and take it to the service counter at the dealership.
Old Jul 28, 2004 | 12:59 PM
boostn420's Avatar
For the mains, I also like perfer to Honda bearings, but if its sleeved and forged internals, why not get the block alignhoned. If I did that then I would just go with ACL's, The differences between the bearings are small that they're still within spec if you mix them.
Old Jul 28, 2004 | 10:08 PM
Default Re: rod bearings and mains (boostn420)
thanks alot guys appreciate it!!
Old Jul 28, 2004 | 11:25 PM
LudeyKrus's Avatar
Yes, the rods should be within OEM specs and you can use the normal bearings.
BUT DOUBLE CHECK EVERYTHING ANYWAYS! Do no skip this part of the motor build process!
My JDM EJ8
Nov 18, 2009 08:55 PM
eg:R
Sep 21, 2006 05:33 PM
1 Cam Wonder
Jan 24, 2005 08:29 AM
db2integra
Sep 20, 2004 08:25 PM
reditr
Jan 17, 2004 12:39 PM
