Rings or Valves
Old Nov 10, 2008 | 07:04 AM
hornetd23's Avatar
Default Rings or Valves
My ZC is smoking only after warm up and acceleration, when the engine is cold there is very little to no smoke. After about 5 min warm up time its starts smoking am I looking at a full rebuild or maybe just valve seals and head gasket replacement.
Old Nov 10, 2008 | 02:27 PM
Brick Top's Avatar
Default Re: Rings or Valves (hornetd23)
smoke during acceleration normally means the piston rings are bad.
Old Nov 11, 2008 | 08:03 AM
srmofo's Avatar
Default Re: Rings or Valves (Brick Top)
do a compression test, record the numbers....and a few teaspoons of oil to the cylinder being tested, redo the test.....if the numbers go up then its your rings, if it doesnt then its your valve seals
Old Nov 11, 2008 | 05:51 PM
ekb16's Avatar
do a leak down test..if u here air coming out of ur dip stick tube then ur rings are bad..if u here air coming out of ur oil cap hole then ur valves are bad
kornkid21792
Feb 20, 2010 09:18 AM
natz20
Mar 15, 2008 09:55 PM
Chuji
Aug 19, 2003 02:06 PM
1.8T_EG
Oct 21, 2002 12:50 PM
