Which Ring is the top and which is the middle?
Old Oct 7, 2005 | 11:36 PM
b18bEKcoupe's Avatar
Default Which Ring is the top and which is the middle?
I bought a set or arias pistons and i want to put the rings on but i cant figure out which is the top and which is the middle. They didnt come with any instructions and ive spent over an hour searching and i cant find the answer. One of them looks kinda carbon coated and is a dull black color. That one is beveled on the inside. The other one just looks like steel or something. I dont know which of them is the top and which is the middle. Thanks for the help.
Old Oct 8, 2005 | 04:21 AM
NJIN BUILDR's Avatar
Default Re: Which Ring is the top and which is the middle? (b18bEKcoupe)
Unless its a custom piston piston setup the rings should be to different heights.The top ring should be 1.0mm and the second should be thicker at 1.2mm.Only one of them should even fit in the top groove.The top ring will install with the inside bevel up if it has one.If it has a dimple or lettering/numbers they should face up.The second ring bevel should face down if it has one,and the dimple/letters/numbers should face up.
Glenn
Old Oct 8, 2005 | 05:01 AM
Both rings have a dimple on them so i think that stide goes up but i cant really tell which ring is the top and which is the middle. They seem to be the same thickness and fit well in each groove.
Old Oct 8, 2005 | 05:29 AM
Default Re: (b18bEKcoupe)
With the dimples facing up the second ring will have the bevel on the inside facing down.The top ring with the dimple facing up will have either the bevel facing up or no bevel at all.The shinny ring should be the top ring and the dull one should be the second ring. Hope this helps
Glenn
pokmijn
Jul 14, 2007 07:11 PM
pwr2lbs
Jan 15, 2005 03:42 PM
Sliced Beard
Jan 22, 2004 06:55 PM
Dan GSR
Jun 30, 2003 12:48 AM
S13 slide
Jan 1, 2002 09:11 AM
