Ring gear in tranny, how low is it supposed to be?
Old Feb 29, 2004 | 07:18 PM
Ek00fbp's Avatar
Default Ring gear in tranny, how low is it supposed to be?
I put the new differential in and it sits about an 1/8th of an inch higher than the case. is that normal or it is supposed to be flush? Also could it be that the bearing im using are wrong? They are supposedly type R bearings the part number is 91005-P80-E31. Are those the right bearing for a b16? Help its been 2 weeks with the tranny off and all apart and I'm dying to finish this already.
Old Feb 29, 2004 | 10:17 PM
Dan GSR's Avatar
Default Re: Ring gear in tranny, how low is it supposed to be? (Ek00fbp)
the ring gear should be basically flush with the case
is this a new differential you put in?
you may need to re shim it
Old Feb 29, 2004 | 11:10 PM
Ek00fbp's Avatar
Default Re: Ring gear in tranny, how low is it supposed to be? (Dan GSR)
yes this is a new differential, so it should definetily be flush hah?
Old Mar 1, 2004 | 04:25 AM
Dan GSR's Avatar
you sure the diff bearings are pressed in all the way ?
Bizarre
Transmission & Drivetrain
Feb 26, 2011 09:05 PM
unclematt
Dec 9, 2008 04:24 PM
welfarepc
Jul 10, 2007 04:41 PM
BenB
Nov 6, 2003 11:09 AM
NipponRacing
13
Sep 5, 2003 06:42 AM
