Ring Gear help please!!!!!!!!!!
Old Sep 12, 2006 | 01:57 PM
Boostin Ex's Avatar
Default Ring Gear help please!!!!!!!!!!
Ok i have a Jdm SiR II b16 tranny with the optional lsd i need to find a replacement ring gear. My ring gear has 14 bolts overthe usdm non lsd ring gear which has 10 bolts.
Here is my ring gear
Here is a normal b16 ring gear
If anybody knows where i can get the ring gear i need please let me know
Thank's
Modified by Boostin Ex at 5:25 PM 9/12/2006
Old Sep 12, 2006 | 04:34 PM
Boostin Ex's Avatar
Default Re: Ring Gear help please!!!!!!!!!! (Boostin Ex)
Bump for someone has to know something
Old Sep 12, 2006 | 04:38 PM
Bense's Avatar
you need a itr ring gear
but i would just go ahead and get a 4.785 itr final drive from hmotors for $350
Modified by Bense at 8:53 PM 9/12/2006
Old Sep 12, 2006 | 04:53 PM
Mista Bone's Avatar
D Tranny Guru
USDM ITR FD, 14 bolt ring gear.........
just as easy to get the JDM FD, but your gonna need to inspect the gear teeth on first and second also. Likely more hidden damage.
Old Sep 12, 2006 | 06:03 PM
Boostin Ex's Avatar
Default Re: (Mista Bone)
Well i was told this was a 4.4 final drive which was fine with me i would be scared of a 4.7 because of my trap speeds in the 1/4 my car was traping 130mph in 4th before the new turbo setuo i should trap in the high 140 mph range so i dont think a 4.7 would work that great since i will be well into 5th gear.
Aslo the 14 bolt itr ring gear what year usdm itr's had these im not seeing a diference on the parts diagrams on acura or honda dealers sites i just dont want to order it if its not the right ring gear cause the dealers here suck and carry nothing in stock.
Old Sep 12, 2006 | 06:54 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (Boostin Ex)
looking on http://www.acuraparts247.com
41233-P80-V00 GEAR, FINAL DRIVEN
Both the 1998 and 2001 GSR and ITR are listed as having the same ring gear.
Hrm.........
Old Sep 12, 2006 | 07:00 PM
Boostin Ex's Avatar
Ok well if you count the number of bolt holes on the mircophice pic it comes to 10 holes i dont know if there pic is off but my diff has 14 bolt holes and so does my ring gear. I will call them tommorow and ask.
Old Sep 12, 2006 | 07:54 PM
Flexmyrex's Avatar
The US ITR/GSR will not work. The only final drive i have seen with that pattern was out of a cable b16 , and gsr. I had a jdm gsr final drive with oem lsd from a cable gsr into 97 hydro gsr. I was going to use the hydro final drive on it but upon reassembly i noticed the two fd did not match, so i went ahead and installed the whole unit (cable diff+FD) everything else stayed in including the hydro counter shaft. You'll need a fd out a b16/gsr cable trans with the same pattern.
Old Sep 13, 2006 | 07:50 AM
SkRiBLaH's Avatar
Default Re: (Flexmyrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flexmyrex &raquo;</TD></TR><TR><TD CLASS="quote">The US ITR/GSR will not work. The only final drive i have seen with that pattern was out of a cable b16 , and gsr. I had a jdm gsr final drive with oem lsd from a cable gsr into 97 hydro gsr. I was going to use the hydro final drive on it but upon reassembly i noticed the two fd did not match, so i went ahead and installed the whole unit (cable diff+FD) everything else stayed in including the hydro counter shaft. You'll need a fd out a b16/gsr cable trans with the same pattern.</TD></TR></TABLE>
listen to this man. for once bense is wrong. with that LSD you can NOT use the GSR/ITR ring gear.
if you take that ring gear off you will notice that it has teeth on its inner diameter as well. special ring gear.
Old Sep 13, 2006 | 08:39 AM
Bense's Avatar
Default Re: (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">
if you take that ring gear off you will notice that it has teeth on its inner diameter as well. special ring gear.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flexmyrex &raquo;</TD></TR><TR><TD CLASS="quote">The US ITR/GSR will not work. The only final drive i have seen with that pattern was out of a cable b16 , and gsr. I had a jdm gsr final drive with oem lsd from a cable gsr into 97 hydro gsr. I was going to use the hydro final drive on it but upon reassembly i noticed the two fd did not match, so i went ahead and installed the whole unit (cable diff+FD) everything else stayed in including the hydro counter shaft. You'll need a fd out a b16/gsr cable trans with the same pattern.</TD></TR></TABLE>
yeah, it's probably better that you listen to these guys. I've yet to actually take a B-series apart, just going off of what people have told me
But this is where I am confused. I thought that the sirII was hydro?
Old Sep 13, 2006 | 09:01 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: (Bense)
those ring gears are pretty hard to find. It will be better if you go with a 10 bolt ring gear and new lsd
Old Sep 13, 2006 | 09:32 AM
charlee's Avatar
Default Re: (2FAST4U831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 &raquo;</TD></TR><TR><TD CLASS="quote">those ring gears are pretty hard to find. It will be better if you go with a 10 bolt ring gear and new lsd </TD></TR></TABLE>
thats gonna be pretty expencive, tho the most reasonable way to get it just right
Old Sep 13, 2006 | 09:41 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: (charlee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charlee &raquo;</TD></TR><TR><TD CLASS="quote">
thats gonna be pretty expencive, tho the most reasonable way to get it just right</TD></TR></TABLE>A used ITR/CTR lsd and used ring gear will set you back about $550. I have only seen this 14 bolt lsd on 1 other thread in the last two years.
Old Sep 13, 2006 | 01:30 PM
egsleepercivic's Avatar
contact japandy on ebay, he doesn't have any for sale right now, but he is in Japan and has sold them in the past. also has a good seller rating.
* ihave never bought anything from him*
also he will probably only sell you the complete LSD
Old Sep 13, 2006 | 01:33 PM
Bense's Avatar
Default Re: (egsleepercivic)
Boostin Ex, Take the diff out and get more pics of the ring gear
Old Sep 13, 2006 | 02:06 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: (Bense)
Here are some pics I found of the diff.
Old Sep 13, 2006 | 03:54 PM
Bense's Avatar
OOOOOOOOOOOOH. I think i'm understanding it now.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">
does that mean that the ring gear has teeth that mesh with the LSD gears?
Old Dec 19, 2006 | 04:01 PM
Bense's Avatar
Default Re: (Bense)
weird, thehatchninja's obd1 jdm gsr swap's trans has this same unit
Old Dec 20, 2006 | 06:18 AM
thehatchninja's Avatar
It's an SIR-G swap dude....haha....haven't you been studying your JDM trivia.
Anyways...yeah, we took my tranny apart yesterday and mine w/ optional LSD has the 14 bolt ring gear. I also want to replace the FD.
BUT...if the OP is looking for a good 14 bolt 4.4 I have one...but I probably need to sell the differential with it.
Old Dec 20, 2006 | 02:11 PM
basically these 14 bolt diffs are from the 92+ JDM DOHC VTEC LSD trannies (B16, B17, B18) Not including the ITR and CTR, which use the same 10 bolt as all the other open diffs..
Old Dec 21, 2006 | 11:29 AM
finding a FD ring gear for these is a lost cause.
Old Dec 21, 2006 | 01:48 PM
Gearspeed-Performance's Avatar
Default Re: (thehatchninja)
I have one $$$
Old Dec 21, 2006 | 01:55 PM
Bense's Avatar
anything greater than 4.4?
Old Dec 21, 2006 | 02:18 PM
Default Re: (Bense)
No 4.4 on that one
Old Dec 22, 2006 | 03:38 PM
i'm going to weld and redrill a 10 bolt i think that will work pretty good
