Ring gapping...again :P
Well guys, I'm hoping to finish this once and for all. I have a B16 w/LS pistons. I bought Hastings rings. My question is, can I reuse them? I didn't really USE them, only drove the car for 10 minutes. Can I take the pistons out, gap the rings, then reinstall? Also, anybody know what I should gap them to for my setup? I'll be running 6-8lbs of boost.
I know, I should have done it the first time!
Thanks,
Goldfingiz
Thanks,
Goldfingiz
why did you buy those rings? should have gotten some weisco piston rings or something like that.........
i would probably buy new rings........you might run into trouble re-using those rings even if they are used in the same cylinder........
