Ring break in while running rich?
Old Jan 5, 2007 | 02:43 PM
nick91civicsi's Avatar
Default Ring break in while running rich?
I am rebuilding my boosted B18C5 at home and I am dropping in some lower compression wiseco pistons. The compression is dropping from 10:5 to 9:5 which i figure will cause the engine to run rich. My question is would this cause problems when trying to seat the rings or not because my tuner is about 20 miles away from my house and according to some people the rings would already be seated after 20 miles.
Also, I am installing a brand new act clutch kit which from my understanding requires atleast a 500 mile break in which would keep me from being able to get the car tuned right away as well as keep me from being able to do a "hard" break in. If anyone can help me out I would really appreciate it.
Old Jan 5, 2007 | 02:54 PM
umop-apisdn's Avatar
Default Re: Ring break in while running rich? (nick91civicsi)
Flatbed...
Old Jan 5, 2007 | 03:23 PM
non-VTEC's Avatar
it may run a slight bit richer but not enough to do any damage.
that is as long as your current tune is good.
Old Jan 6, 2007 | 08:45 AM
Default Re: Ring break in while running rich? (non-VTEC)
thanks for the replys, any other opinions???
Old Jan 6, 2007 | 06:36 PM
91SiZ6's Avatar
The clutch is a friction surface just like your brakes. Do you baby your brakes for 500 miles after you change them? Of course not. A proper engine break in will break in your clutch and flywheel at the same time.
Old Jan 7, 2007 | 07:41 AM
Default Re: (91SiZ6)
hmm thats an interesting point but iv never heard of doing a brake pad break in and iv always heard that a clutch requires a break in period even from the clutch manufacturers...
Old Jan 7, 2007 | 12:41 PM
DonF's Avatar
Default Re: (nick91civicsi)
On "race" cars you do bed-in the brake pads and new rotors.
Old Jan 7, 2007 | 12:55 PM
91SiZ6's Avatar
"Take it easy" basically means, don't bog the engine and don't shift at WOT...or in other words, don't beat on it yet. As you progressivey take your engine to higher RPMs with more throttle your clutch and flywheel will break in.
Bedding in brakes is pretty much the same thing. You make a set number of progressively harder stops from higher speeds.
Old Jan 8, 2007 | 10:55 AM
so bottom line, I need to know if I should just drive the car up to the tuner shop after the first startup and just seat the piston rings that way even with the car running a bit rich or not? Its about a 20 mile drive and i can take the feeder roads instead of the highway to avoid constant rpms....
thanks again
Old Jan 8, 2007 | 01:58 PM
91SiZ6's Avatar
20 miles? Get it towed if you can. That's the safe answer.
Old Jan 9, 2007 | 05:49 PM
ok so best thing would be to just tow it to the shop and start it up there for the first time and let my tuner adjust the airfuel while the car is idling during warm up then go ahead and do some pulls on the dyno to seat the pistons and eventually start tuning?
Old Jan 9, 2007 | 06:56 PM
91SiZ6's Avatar
Yep. Except they'll probably be tuning on those first pulls, too.
Old Jan 11, 2007 | 03:39 PM
ok then, thanks for the help
Old Feb 3, 2007 | 08:53 PM
Ok Im finally done putting the car back together but id like to know if it would be ok to start the car and let it idle until warmed up and then shuting it off, just to make sure everything is ok before getting it towed over to my tuner or if that would in any way cause problems with the new rings?...
Old Feb 3, 2007 | 09:01 PM
SlowReaction's Avatar
Call the tow company and just take it to your tuner. Thow it on the dyno and start tuning.
tshracing
Sep 16, 2006 04:21 PM
Baron55
Jul 12, 2006 10:03 AM
downeyballz
Aug 24, 2005 12:08 PM
HS2G
10
Apr 20, 2004 11:38 AM
douglas_be
Mar 29, 2004 01:31 PM
