rich or lean
Old Apr 19, 2002 | 05:43 PM
DOHCTOR's Avatar
Default rich or lean
i was debating with a coworker. saying 14.1 is stoich/lambda what will make more power a lean mixture or a rich mixture. i know every engine set up is differrent but is there like a general tuning procedure
Old Apr 19, 2002 | 11:41 PM
tinkerbell's Avatar
Default Re: rich or lean (DOHCTOR)
shouldn't the mixture be dependant on load?
t..
Old Apr 20, 2002 | 07:01 AM
Kataku2K3's Avatar
Default Re: rich or lean (tinkerbell)
That is a lil rich, normally you want 14.7:1 but to get more power on an all motor setup you want to see what you can lean out when you tune it.
Old Apr 20, 2002 | 12:24 PM
KevronsEG's Avatar
Default Re: rich or lean (JDMspecEG6)
so you wnat to be lean
Old Apr 20, 2002 | 06:07 PM
tinkerbell's Avatar
Default Re: rich or lean (CIV616)
does the PGM-FI computer go slightly rich at WOT?
Old Apr 21, 2002 | 04:36 PM
Accorden's Avatar
The PGM-FI is going to give the best mix for the need. Now about the lean or rich mix it's up to you and the air going in to the engine too much gas no go, and too much air and no go. So you have to fing the best balance if you have good air( cold and dense) you run rich, and if the air is not so good( warm and not dense) you run lean. So you have to find the one for your setup because too much in the wrong situation and you get nothing. You also want to take in to acount gas mileage.
spooniq
Honda S2000
Jan 20, 2006 09:15 AM
homesauce
Dec 3, 2003 02:15 AM
allmotorEG-SI
Nov 21, 2003 11:29 AM
sslude
Jan 5, 2003 01:49 AM
cruzersi99
Dec 8, 2002 01:59 PM
