reversing engine rotation?
Old Dec 10, 2006 | 11:12 PM
racerpat94's Avatar
Default reversing engine rotation?
what exactly is involved in reversing the rotation of an engine? from the minimal and conflicting info in the searches, i have gathered that the lower end needs no modification, but that the changes needed to be made in the head, and the firing order. so..
would the intake/exaust cams need to be switched? as well as IM, fuel, EM, etc.? or do these components stay in their original places and the firing orders switched?
i saw that some race teams are reversing the rotation of their engines, just to expand their tranny options. (joetech's drag scion for one) just curious about how this works. TIA
Old Dec 11, 2006 | 11:16 AM
jays93eg6's Avatar
Default Re: reversing engine rotation? (racerpat94)
wow thats a 1st for me. I am in for some more on this one.
Old Dec 11, 2006 | 11:48 AM
Perfectionist's Avatar
I have no idea, but i would assume the engine really doesn't care much which way the crank is turning since the piston motion is up and down. The cam lobe profiles may be a problem if they are turning backwards, but otherwise should stay in their original configuration, I would think.
I would imagine the water pump and oil pump would need to be modified, as well as any tensioners.
Interesting, thought though. (You have too much time on your hands )
Old Dec 11, 2006 | 12:27 PM
Crazydave's Avatar
Default Re: reversing engine rotation? (Perfectionist)
you would probably have to flop the motor around in the engine bay too...
otherwise, you'd be going pretty fast in reverse!
I think it would be cheaper and MUCH easier to get a motor that spins the direction you want.
Old Dec 11, 2006 | 01:28 PM
blinx9900's Avatar
Default Re: reversing engine rotation? (Crazydave)
agreed this is crazy talk! crazy! oh my god i just noticed your name is crazy dave for some reason that makes your question ok, lol how weird! i think you'd need a different starter...
Old Dec 11, 2006 | 05:54 PM
02 accord's Avatar
Default Re: reversing engine rotation? (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">i think you'd need a different starter...</TD></TR></TABLE>
Rewire the car for a positive ground. That will reverse the starter. Or just fix the starter by reversing its pos/gnd.
As for the engine rotation, redo the timing belt, so that the cam(s) still rotate in the original direction.
Old Dec 11, 2006 | 06:20 PM
NJIN BUILDR's Avatar
Default Re: reversing engine rotation? (02 accord)
[QUOTE=02 accord]
QUOTE]
That's a lot of work but it still won't work.The drive is directional.
This has been done on a B.New cams and a new tensioner set up are the biggies.Then you can run a standard rotation transmission (many more choices).
Old Dec 12, 2006 | 10:10 AM
racerpat94's Avatar
Default Re: reversing engine rotation? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">
This has been done on a B.New cams and a new tensioner set up are the biggies.Then you can run a standard rotation transmission (many more choices).</TD></TR></TABLE>
kseries starter and trans on a bseries? could be sweet. i guess in the long run a full K swap would be much easier and cheaper. but this concept seems really interesting.
thanks for the input guys.
Old Dec 12, 2006 | 10:50 AM
thesmogman's Avatar
Don't forget the head. Valves would need to be switched. Tensioner would be on the otherside of the belt. Water pump needs to be reversed. Oil pump would suck instead of blow.
I would start with a different motor that is already the way you want tit
Old Dec 13, 2006 | 05:21 PM
Bense's Avatar
Default Re: reversing engine rotation? (thesmogman)
Old Dec 13, 2006 | 05:57 PM
Default Re: reversing engine rotation? (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">
It gives me a headache just looking at it......but I just can't stop looking.
Old Dec 13, 2006 | 06:09 PM
racerpat94's Avatar
It gives me a headache just looking at it......but I just can't stop looking.</TD></TR></TABLE>
i was just thinking the same thing!
Old Dec 13, 2006 | 06:46 PM
Bense's Avatar
i think what they did was flip the cams around and put the head on backwards. It was some crazy euro team that wanted ram air
Old Dec 13, 2006 | 09:40 PM
rip94delsol's Avatar
Default Re: (Bense)
i get it.... wait no i dont....hold i know Im confused, thats what it is.
thats alot of work. but what about the trany cant you just change the way the tranny moves the wheels...
Old Dec 13, 2006 | 09:52 PM
Bense's Avatar
I don't think that you'd want to reverse a tranny.
Old Dec 14, 2006 | 08:48 AM
thesmogman's Avatar
Default Re: (rip94delsol)
That one was too early for me too. (headache) but whoa.. I, I, I, dumbfounded...
.... damn.
Old Dec 14, 2006 | 09:36 AM
racerpat94's Avatar
Default Re: (thesmogman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">I don't think that you'd want to reverse a tranny.</TD></TR></TABLE>
definately not. especially if the tranny has helical gears. what are the two devices mounted on the each side near the oil pan? i would assume a custom alt and an custom water pump?
Old Dec 14, 2006 | 10:26 AM
DonF's Avatar
Default Re: (racerpat94)
We converted B series 1.8 and 1.6 engines to clock rotation 10 yeare ago. You need custom cams, some work in the oil system, a dry sump oil pump, a little work in the water passages, a mugen "clockwise" water pump impeller or the one we made, plus a different belt tennsion ing system. We used a Tilton starter for a Posche and a custom starter bracket for it, I still have one of those lying around.
Old Dec 14, 2006 | 10:33 AM
racerpat94's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">We converted B series 1.8 and 1.6 engines to clock rotation 10 yeare ago. You need custom cams, some work in the oil system, a dry sump oil pump, a little work in the water passages, a mugen "clockwise" water pump impeller or the one we made, plus a different belt tennsion ing system. We used a Tilton starter for a Posche and a custom starter bracket for it, I still have one of those lying around.</TD></TR></TABLE>
what was your reason for doing it? what transmission did you use? custom mounts, or stock location?
Old Dec 14, 2006 | 10:50 AM
DonF's Avatar
We did the first rear wheel drive Acura for GT3 in the SCCA. We also did Ralt and swift conversions for Formula Atlantic and CSR in SCCA using the B-16
Old Dec 14, 2006 | 11:16 AM
d16dcoe45's Avatar
Default Re: (DonF)
That was a BTCC 2.0 liter f20b or h22 right? I heard some teams would spin the head around for precisely the reason you said--to have the intake facing the front of the car--8500 rpm ceiling and over 300 hp--they must have been doing something right!! I think that b16 in the Formula Atlantic is awesome Don,--I had no idea you didn't have to use the 4age until you told me. The current claim--even in a Toyota ad from about 2 years ago was 255 hp (crank) at 1600cc. Were your b16s in that area?
Old Dec 14, 2006 | 12:07 PM
DonF's Avatar
Default Re: (d16dcoe45)
248 crank. And about $12,000 cheaper.
Old Nov 11, 2019 | 10:40 PM
DCB-20R's Avatar
Is there anyway to bring these images back to life? I'm researching a "super-touring" inspired B series build and they would be a huge help! Fingers and toes crossed.
Old Apr 16, 2020 | 07:23 PM
JDM_ego2033's Avatar
5 Year Member
I can’t see a K series transmission mounting to a B series since they mount on opposite sides
Old Apr 17, 2020 | 06:42 AM
hondamark35's Avatar
think about that one a little bit more. why is a B-series on the left and K-series on the right? if you reverse the rotation of a B-series...
