reverse/idler fork
Old May 26, 2003 | 04:28 PM
1slob16a's Avatar
Default no reverse!
i just bought a del sol vtec with no reverse! the last owner said the car was stuck in reverse, his son then kicked the shifter to get the car out of reverse. it shifts fine through all the gears, except of corse rev. which when you try to engage, there is nothing there. a firm stop, just like looking for 5th gear in a 4spd. some one please help. i have the trans out and the case in two.
Old May 26, 2003 | 10:03 PM
3rdGteg's Avatar
Default Re: no reverse! (1slob16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slob16a &raquo;</TD></TR><TR><TD CLASS="quote">when you try to engage, there is nothing there. a firm stop, just like looking for 5th gear in a 4spd.</TD></TR></TABLE> Take a look at the reverse gear synchro sleeve; slide it up and down and look at the synchro itself; you might have to pull the whole thing out off the shaft and look on the inside of the sleeve--prolly all chewed like one of my old ls trannies that wouldn't go into 4th gear (like there was no gear slot at all). The chewed up inside of the sleeve made the sleeve unable to slide over the 4th gear synchro so I couldn't shift into 4th. Just check the sleeve and synchros and wouldn't hurt to check the shift fork also while it's apart.
Old May 27, 2003 | 07:13 AM
Aron Parsons's Avatar
Default Re: no reverse! (3rdGteg)
Well if it's anything like an L3 tranny (which I assume it is), there is no synchro/shift fork like the rest of the gears. Reverse is alone with a small fork to control it. The only way you're going to be able to diagnose the problem is to crack the tranny open and take a look. If you don't hear any metal noise now, nothing was broken likely. It may just be out of place, jammed together, or many other possibilities.
Old May 27, 2003 | 12:49 PM
1slob16a's Avatar
Default Re: no reverse! (Aron Parsons)
i have the tranny in two, and i see the reverse fork, i think? from what i can see reverse is alone, and controlled by the reverse fork. when i shift the trans manually the linkage never moves the gear on the shaft. should the gear move on the shaft? or is it pressed on?
magic94gsr
Jun 12, 2008 03:16 PM
jdm_DC2R
Mar 21, 2006 08:37 AM
onyx00
Feb 25, 2005 11:45 AM
zbower7
Feb 21, 2004 03:31 AM
HatchBox
15
Dec 19, 2003 09:12 PM
