reuse headgasket?
Old Feb 15, 2006 | 06:34 PM
coconutsoldier's Avatar
Default reuse headgasket?
I did search, but feel my situation is a little different.
Most people advised against it, but my engine hasn't even been started yet.
I bolted the head down a couple months ago, and just found out a few days
ago that the head was used for a ls-vtec setup, so one of the original oil passages
has been plugged. I want to unplug the passage so I don't have to build an external oil line. Anybody think I should still get a new gasket?
Old Feb 15, 2006 | 06:39 PM
theneil's Avatar
Default Re: reuse headgasket? (coconutsoldier)
someone once told me that reusing a head gasket was like reusing a condom, you could do it if you really wanted to, but seriously... would you?
Old Feb 15, 2006 | 06:44 PM
Default Re: reuse headgasket? (theneil)
I would consider it if condoms cost 90+.
Old Feb 15, 2006 | 08:04 PM
sc4dr's Avatar
I believe its all in the crush of the gasket, not if its been run or not.
Old Feb 15, 2006 | 08:45 PM
ITR#132's Avatar
done it before; I had no problems.
Old Feb 16, 2006 | 10:21 AM
SteveoBA8's Avatar
Default Re: (ITR#132)
REPLACE THAT ****
Old Feb 16, 2006 | 10:38 AM
turbod92si's Avatar
copper seal it i think it'll be fine.
Old Feb 17, 2006 | 05:27 AM
Lsos's Avatar
I guess if it was a crappy engine I didn't care about I would consider it, but I'd be very weary. If I cared about the engine, I would replace it.
Old Feb 17, 2006 | 10:06 AM
B16aSir2's Avatar
Default Re: reuse headgasket? (Lsos)
Replace, don't listen to these fools. 60 bucks vs pulling the head back off.....Hmmm let me think about that one. Gaskets are designed to be made of thin metal which is easily crushed upon torqueing on the head. The reason why it crushes it to form around the area it is closing off to ensure no leaks. If you reuse the same one and don't torque it exactly the same, you are going to run into problems everytime.
Old Feb 17, 2006 | 10:38 AM
Default Re: reuse headgasket? (B16aSir2)
That is exactly what I thought, but I had a tech at a honda dealership say his friend with the same setup has used his headgasket two or three times with no problems. I am thinking I will most likely get a new one.
Thanks for the responses.
LSteggyguy
May 29, 2014 09:49 PM
umby
12
Jan 14, 2010 03:18 PM
lexluther
16
Jan 4, 2010 09:51 AM
GSR4door1
Apr 24, 2004 08:02 AM
89 CRX SI
Oct 4, 2002 11:07 PM
