Retarding or Advancing?
Old Mar 10, 2004 | 06:17 AM
ranta18's Avatar
Default Retarding or Advancing?
Some thoughts I had about the whole milling the head causing the cams to be retarded issue. It could just be too early and I'm not thinking right. This is on a H22.
The motor turns counter-clockwise when looking at the cam gears. When milling the head, it decreases the distance between the cam gears and crank. The distance between the crank and water pump won't change. The distance between the cam gears and tensioner will change, but is allowed to because the tensioner takes up the slack. Now, when the head is brought closer to the crank, the cam gears get closer to the water pump. Remember that the crank to water pump distance is the same and tension should be the same between them. Because its a cogged belt, that means the cam gears would have to turn counter-clockwise in order to keep the same tension between it and the water pump. Then the the tensioner would take up the extra slack. If the cam gears rotate counter-clockwise, that means its advancing the cam right? I might be having a HUGE brain fart right now and I'm the one thats getting retarded...LOL. If the cam gets retarded, then the cam gears would go clockwise, which means the crank wouldn't be at TDC anymore. Someone tell me what I'm missing.
Old Mar 10, 2004 | 06:26 AM
ranta18's Avatar
Default Re: Retarding or Advancing? (ranta18)
Unbolt the head keep the carnk at TDC and pull it up a little and the cam gears should rotate clockwise right?
Old Mar 10, 2004 | 07:09 AM
mmuller's Avatar
Mad Scientist
for every .012 you remove, cam timing is retarded 1 degree.
After you dial that with cam gears, set base ign. timing.
Old Mar 10, 2004 | 10:26 AM
ranta18's Avatar
Default Re: Retarding or Advancing? (mmuller)
Dude, thats not what I'm asking. I know its .012. What I'm asking is for an explanation as to WHY they are retarded and not advanced as to the thinking I explained above.
Old Mar 10, 2004 | 10:46 AM
mmuller's Avatar
Mad Scientist
DUDE, by having less distance from crank to cam on ex side and from cam to water pump on intake, the tensioner takes up for the slack thus moving the cams clockwise.
Old Mar 10, 2004 | 11:09 AM
ranta18's Avatar
But then if that happend the belt would be lose bewteen the water pump and crank.
Check this out for a picture of it...
As you lower the head, the cams rotate counter-clockwise because the distance from the water pump to the cam gear is less. In order for it to remain in tension, it has to rotate counter-clockwise. Think of it without being able to take the belt off.
Old Mar 10, 2004 | 06:17 PM
mmuller's Avatar
Mad Scientist
I dont know what engine your talking about...but h,b and d series only have one tensioner on the intake side.....so your pics are wrong
Old Mar 10, 2004 | 06:39 PM
ranta18's Avatar
Oh sh*t, I was totally thinking wrong. Mind blank on the tensiorer position. LOL. You're right. Thanks. It must have been the lack of sleep.
o_Rage_o
Nov 10, 2016 06:32 PM
komat
Jun 12, 2006 02:27 AM
raiden571
May 20, 2006 06:37 PM
Muckman
Sep 22, 2004 09:44 AM
