replacement TPS sensor from Honda
Old Aug 10, 2003 | 09:24 PM
GSRswapandslow
Guest
Posts: n/a
Default replacement TPS sensor from Honda
Most people know that to get a TPS you have to purchase a throttle body from Honda. Well, not any more. The 954RR's TPS is the same thing as the civic/teg one. You have to go to a motorcycle dealership to get it...but it's the same thing.
enjoy
Old Aug 10, 2003 | 09:57 PM
PhatOptimo's Avatar
Default Re: replacement TPS sensor from Honda (GSRswapandbanned)
Do you know what they are charging for them? A part number would be cool too.
Old Aug 10, 2003 | 10:32 PM
mmuller's Avatar
Mad Scientist
Default Re: replacement TPS sensor from Honda (Quantum_CRX)
good info rob
Old Aug 11, 2003 | 05:37 AM
rsbad454's Avatar
Default Re: replacement TPS sensor from Honda (mmuller)
yeah how much?
Old Aug 11, 2003 | 06:48 AM
Benny Hinn's Avatar
Since there is a "No Tamper" policy on USDM engines due to emissions(such as the TPS), there are rivets to secure the US TPS. If you notice there are star bolts that fasten the JDM TPS to the throttle body. The same method of fastening is used on the motorcycle TPS US or JDM as the JDM automobile TPS, which makes removal much easier. The TPS can be bought straight from the parts counter at a Honda motorcycle deaer, but it is cheaper to find some orphan sohc TPS.
It is good to know if you are in a bind for a good TPS.
Good luck with your ITB project, let me know if there is anything I can do for you.
Benny
Old Aug 11, 2003 | 08:34 AM
GSRswapandslow
Guest
Posts: n/a
true, it's usually cheaper to get one from a donor motor...but there are the times when you need one quick...and a GOOD one.
i can't remember the price off hand, but it was under $40 for a brand new part
and the ITB project...the biggest thing is going to be the plenum since it's going to be boosted...
Old Aug 11, 2003 | 09:32 AM
LudeyKrus's Avatar
any chance this TPS would also fit an H22?
Old Aug 11, 2003 | 09:44 AM
GSRswapandslow
Guest
Posts: n/a
i'm pretty sure that they are all the same
so yes
Old Aug 11, 2003 | 10:56 AM
LudeyKrus's Avatar
Default Re: (GSRswapandbanned)
how much did they run?
Old Aug 28, 2003 | 07:25 PM
McDade's Avatar
Default Re: (LudeyKrus)
would a crx dx tps fit a b18c1 throttle body?
Old Aug 28, 2003 | 10:28 PM
mmuller's Avatar
Mad Scientist
Default Re: (McDade)
all honda tps's are the same(cars)
Modified by mmuller at 1:53 PM 8/29/2003
Old Aug 29, 2003 | 07:02 AM
JasterM5's Avatar
OK I tried to look up the part number online but i'm not sure if this is the part or not. I think its number 14 but i'm not entirly sure. You can click the pic to see what I mean.
http://houseofmotorcycles.bike...900RR
Old Aug 29, 2003 | 07:14 AM
MightyMouseTech's Avatar
Default Re: replacement TPS sensor from Honda (JasterM5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasterM5 &raquo;</TD></TR><TR><TD CLASS="quote">OK I tried to look up the part number online but i'm not sure if this is the part or not. I think its number 14 but i'm not entirly sure. You can click the pic to see what I mean.
#14 is the fuel pressure regulator
The TPS is not shown seperately in that picture, it is on the far side of the throttle assembly.
On a side note, anyone know the size of those throttles?
Old Aug 29, 2003 | 09:42 AM
GSRswapandslow
Guest
Posts: n/a
we have 2 sets of 954rr's in hand...
they are ventruied. goes like..40-38-42 or something...can't remember...need to remeause.
lines up perfectly with the D series head though, hehe
Old Aug 29, 2003 | 09:45 AM
Darkteg's Avatar
New User
Default Re: (GSRswapandslow)
i have the 929 TPS, and they ARE NOT THE SAME as our B-series TPS.
physically the same, but they run backwards...
Old Aug 29, 2003 | 09:48 AM
GSRswapandslow
Guest
Posts: n/a
ok, i never said **** about the 929, READ...954
they are the SAME part number as the Honda car piece
Old Aug 29, 2003 | 12:04 PM
Zimmlude's Avatar
BTW, the US TPS is not riveted to the TB. The fasteners are those screws that the heads break off of when they are tight. All you need to do is cut a slot in the top of the "rivet" and unscrew it.
HTH,
Old Aug 29, 2003 | 12:52 PM
GSRswapandslow
Guest
Posts: n/a
they are put on in a manner as to keep them from being tampered with....
Old Aug 29, 2003 | 05:00 PM
JaeOne3345's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow &raquo;</TD></TR><TR><TD CLASS="quote">ok, i never said **** about the 929, READ...954
they are the SAME part number as the Honda car piece</TD></TR></TABLE>
even the 954 is reversed. u just have to reverse your signal wires on the tps.
Old Aug 29, 2003 | 07:28 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by McDade &raquo;</TD></TR><TR><TD CLASS="quote">would a crx dx tps fit a b18c1 throttle body?</TD></TR></TABLE>
Well, yes it "will" work, like is posted above they are wired in reverse. All Civic/CRX's with DPFI have the TPS that works backwards. So when you wire up the B18, you have to flip the wires around on the plug for the TPS, if you use one from DPFI Civic/CRX. HTH
Old Aug 30, 2003 | 05:24 AM
Benny Hinn's Avatar
Default Re: (Darkteg)
It takes 3 seconds to rewire/switch the TPS wires.
If you do not have access to another good TPS, the Honda MC parts counter is a perfect alternative to buying a whole throttle body just for the TPS.
Whenever you replace a TPS, it needs to be adjusted. During adjustment it would be obvious that the signal wires need to be reversed.
sgnlab
Oct 14, 2009 03:57 AM
eM1<3
Mar 17, 2009 07:17 PM
nutball72
Nov 11, 2006 07:14 PM
Audi RS4
Sep 17, 2004 09:52 AM
evo
Apr 9, 2002 09:39 PM
